CTEK - Cigarette Lighter Vs Comfort Indicator?
I'm looking at picking up a new CTEK charger for my cars
I've seen and heard quite a few people use the CTEK comfort panels rather than plugging straight into the cigarette lighter, but I've never heard why
Can anyone tell me why these connectors are preferred to the lighter socket?
https://www.google.co.uk/search?q=ct...FcsTGgody24Pyw
you should have the alligator ( large ) red/black +/- std connectors, and also some that are o ringed connectors that have to be fastened. pos and neg for both.
then the more convenient option for another 10/20 bucks is the cig light adaptor. but that is the only connection not requiring a separate ground. but there are two SETS of cables that are included when you purchase the ctek c3300 that have a plastic connector in the sequence so you can switch from cables to cig adapter etc..
Yea, my cig power isn't constant (shuts off)....i've got the car hooked up to alligators right now as my o rings are used on my '55 (just ordered another set)
I'm actually running a CTEK MUS 4.3 but I don't think that will cause any issues
but the cig light adapter is constant,..and will consequently "always" draw current if there is ANY juice in the battery.. its the charger itself that goes "off". if that makes sense. the alligators are obviously fine since most use those, but you have to undo the battery cover, leave the frunk open etc and all that sh*t, while the cig lighter thing is well...
i'm lazy
not sure what "shuts off" means since the ctek i have "trickles" and "auto" shuts itself off for a minute, then goes back "green" when fully charged. sorry/confused.
i'm lazy
i'm lazy
Popping the hood isn't bad for me.
ctek + cig adapter working flawlessly here the past 3 years. Each dealer visit in the spring they tell me the battery is in perfect condition (and the battery is about 6 years old now).
My only complaint is the cig adapter doesn't seem to work on some of the newer cars (didn't work on the GTR or the M6).
Just got a ctek 3300 last week and hooked it up directly to the battery (also have the cig adapter on the way). It's been 3 days so far and it's still charging. Is this normal? I had read others show fully charged over night.
wondering if this means I need a new battery as the current one isn't holding a charge.
