MAFs are annoying
MAFs are annoying
So I get a code for the maf occasionally so I finally decided to change it. Car ran like complete garbage, couldn't even give it gas. Put the old one back in....runs like a champ. I did not buy an oem maf, but it was the same PN.
the sequence of your activity is pretty hard to follow/understand from the post!
i'm reading this as, you had maf issues that didn't go away once NEW maf was installed. but once the OLD one was re-isntalled the world was right again. if true, that is a riddle.
Did you confirm the PN on the new MAF was the same as the PN on the old MAF?
If the MAF's are truely identical the behavior suggests when you connected the new MAF there was a problem with its electrical connection.
There is yet another possible explanation for the new MAF's behavior: It is defective out of the box.
What error codes are you reading from the DME that point to the MAF being the problem?
$5 says it was a knockoff MAF and man some of those are complete junk, worse are the counterfeits that have everything but the hologram sticker on them and I'm betting that isn't far behind. MAF are a great idea as direct sensing airflow is good for fuel calcs but they tend to be sensitive, restrictive, and have a limited flow range that we exceed on these cars somewhat easily. Yes, MAF are a PITA...
Thought it was pretty clear.
1. Got a maf code
2. Replaced maf
3. Car ran horrible
4. Put back in original maf
5. Car runs normal
Only thing I did not mention is the car always ran perfect, but got the maf code occasionally, so I just changed it for the ****s of it.
1. Got a maf code
2. Replaced maf
3. Car ran horrible
5. Car runs normal
The reason in changing it is because I'm chasing the psm abs lights that come on under boost. Maf was the last thing to check before I said f it, I don't care anymore.
I believe this is the reason for your troubles. You likely installed a Chinese knockoff MAF. In 5 years of tracking these cars, I've never had any issues whatsoever with a genuine article Bosch MAF. Zero... A solid tune with the correct hardware and a genuine MAF should not give you any trouble.
i'm with hound on this one, if there's even a "chance" you've installed a maf other than a bosch OEM 124.00? get rid of it asap. even though "986boxter" part is purported to be exactly the same? i wont even mess with that!
stay away from knockoff mafs!
i keep forgetting the bremi as an oem an option, since it ptobably is! but then i haven't fried a maf even with a raised limiter since i got rid of the oiled flat panel filter. i wonder if there is a coincidence? this last bosch has been in for at least five years trouble free. ( now watch lol)
