Running rich problem
Running lean problem
Hi guys & gals. Im new here although being a Porsche guy for a decade.
Currently running 996tt -01 which Ive been building/modificating for a year already.
Im getting o2 sensor code p1118, replaced with oem Bosch ones, but still. I noticed when accelerating with part throttle 1000-1200rpm the afr jumps to 20 and the engine hesitates obviously. Harder acceleration no problems. Replaced also the diverter valves. Im running mafless Cobb tune, appeared already before though. Searched for vacuum leaks but so far nothing. Maybe I should lower the engine to reach the whole vacuum system? Any input on this appreciated!
Thanks. -JP
Thanks. -JP
20:1 is lean not rich, extremely lean. Since you've got a Cobb have you been trying to pull fuel to correct a "rich condition"? If so stop lol! How exactly did you search for,leaks, boost leak test or just visual? If simply visual do a boost leak test...
Thanks. -JP
Thanks. -JP
I've been chasing a similar problem on my 01'TT for 6 months. I still have not found the problem. I've checked / replaced just about every sensor,solenoid, check valve, O2's, MAF etc...I've done several boost leak & vacuum tests. No leaks. The car runs terrible other than at full throttle. Full throttle is much better but still is not right.
Interestingly, I also have a Cobb tune + Cobb injectors, billet turbos, IPD plenum, 997 TT throttle body, intercoolers, new coils, new MAF. I also tried Cobb's mafless but I still had the same issues.
Interestingly, I also have an 01' TT. I wonder if this is only an issue with 01' TT's ? I think(different part #) the 01's have different vario cam actuators/solenoids and programming than 02' to 05'. I wonder if the 01' TT require different mapping?
Karl
He's running MAFless, unmetered air was my first thought too. Sounds like a tuning issue though?
dnelson
02-09-2016 03:35 PM
ECS Tuning - VW
01-13-2016 11:54 AM
magnus911
Cayenne 955/957
01-10-2016 09:38 PM
