Need suspension input PSS10 and Tarett drop links
Old 07-29-2016, 05:53 PM
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
Had a PSS10, with Tarett drop links front and rear, set installed about 6 months ago by a shop in Houston, drove about 500 miles. Have been hearing some clunking upon turning wheel left and right.
Went to have a look here is what I found,
Can someone guide me on how to fix this?
The locking rings are loose.
Old 07-29-2016, 06:12 PM
SpeedAddict's Avatar
SpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to all
See post #183 in this thread. https://www.6speedonline.com/forums/...-overs-13.html
I think you may need these curved drop links. I would like to know too since I have PSS10's on order.
Old 07-29-2016, 08:30 PM
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
On the pss9 version of those links there is a offset detail and 3 thick spacer washers on top that is missing from your install. I just installed mine last week. Maybe those links are the stock suspension version?
Old 07-29-2016, 09:01 PM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Yep you definitely need spacers with longer bolts and you have to really tighten them up hard.
Old 07-29-2016, 09:45 PM
From Tarett's website and confirmed with Ira
Drop Link (pr), Front, 996/997/986/987/981/991
(Model = 996/997 TT/C4 with PSS9 or 10 (Part #996TTFDLNK))
Longer bolts would make sense.
Can you post a pic of the spacer? That is if you happen to be underneath
I'll email Ira and see what can be done.
Old 07-29-2016, 10:01 PM
JimTT's Avatar
Old 07-29-2016, 10:06 PM
JimTT's Avatar
Edit;
You will notice I shaved off and rounded a small section of the area you were binding with even with the spacers.
That helps, dust boots, bolts and spacers is what I need. Thanks guys.
Jim, you end up getting curved ones, similar to the ones that come with the coilovers?
Old 07-29-2016, 10:07 PM
Looking at my photo it pulled the metal bracket over as well.
Old 07-29-2016, 10:11 PM
JimTT's Avatar
I did go with curved ones 2nd time but they weren't quite long enough which resulted in stripping the thread so I went back to the straight ones with with better position/angle including minor grinding part of the front suspension uprights.
Old 07-30-2016, 06:01 PM
So took a photo of the link connected to the sway, and it does have a spacer.
It almost looks as though if I flip the link around it could work without binding?
Old 07-30-2016, 07:03 PM
r6vr6's Avatar
Yeah it is upside down there should be 3 thick washer spacers too that go next to the machined eyelet piece.
Old 07-31-2016, 02:50 AM
JimTT's Avatar
Spacers are in the wrong section of drop links !!!! They should be on the upper section, not lower. The installer got it wrong, big time!!!! I'd go back to them and with lots of questions why they did this.
Old 07-31-2016, 07:48 AM
Yeah, not going back there, there were some other non mechanical stuff that didn't go so much. I'll flip them around and hopefully problem solved.
Thanks for the input everyone.
Old 07-31-2016, 01:57 PM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
When flipping them around I would check the lengths as well as one of the lock nuts is loose and also looks like the arb may have been contacting the driveshaft.
heavychevy
15
04-19-2016 09:14 AM
CBRacerX
03-29-2016 11:46 AM
82chilam
03-27-2016 12:22 AM
Quick Reply: Need suspension input PSS10 and Tarett drop links
