Tire wear problem solved. Thanks to all here!
A few members helped me decide what parts to do to get rid of this ridiculous tire wear issue. Use to go through rears in 3-5000 miles. I did the tarrot monoballs and solid LCA bushings. This was my tire tonight after 5000 miles. The alignment is set at -1.6 camber and .25 toe. Awesome!! Thanks again to everyone who helped :-)
so you feel the more solid mountings are the reason for the reduced wear as compared to the oem rubber mounts? im guessing the rubber allows for more movement in the suspension and more wear? how is the ride? super stiff? would you think this is practical for a street car?
[url=https://flic.kr/p/M7y1us]
[url=https://flic.kr/p/LHFBRW]
You were the one that helped! Thank you again.
Have monoball toe links, LCA with solid pucks and monoball ends, and toe adjuster locks coming from Elephant. Anything else needed to lock the rear down and how much noise am I likely to incur? Shop doing the work seems to think this is overkill lol.
I am very much interested in reducing the inner rear wheel wear on my 996tt (with 997tt wheels and 325/25/19 tires). The inside wears down to the chords in 8k miles while the outside tire looks near new. I was planning to pay $70 or whatever to switch tires on rear wheels (they are directional so can't just swap wheels) to help even out wear on my new set of tires.
Any links to needed parts is much appreciated. Never heard of this stuff before...
why? I don't even run that extreme on my road race car. If you are just a highway roller then all you are doing is giving less stability at speed and braking.
I agree, if your car is just used for cruising/rolling, you are better off with less camber to increase contact patch in a straight line.
