How many miles from your original stock clutch?
I'm at 21k and starting to feel some slip during full acceleration, right after gear changes. I don't have any considerable "power adders", just updated OEM parts: plugs/coilpacks/clutch accumulator plus an aftermarket x-pipe exhaust... was considering a tune but I guess a Sachs 2.5 w/ DMFW is next instead... just curious what kind of miles you guys got out of your stock clutches before they started to show signs of letting go.
Thanks in advance!
Forgot to mention they are all street miles. No track time.
Thanks in advance!
65K, bought it with 55K on it. It's original, but the tune i have on it now may be eating away. Have a new clutch ready to go in when the day comes.
This will be the first car ive had to replace a clutch on. I put 90K on my last GTO on stock clutch.
Thanks in advance!
Thanks in advance!
Originally Posted by '02996ttx50
or not. my car's had 16/24's and other asst bolt ons for at least! 90 of its 138k miles. never an issue. just dont feather the left pedal lol
Thanks in advance!
Thanks in advance!
My experience with my 2003 Turbo is the Turbo requires very little RPMs above idle and very little clutch slippage to get the car moving from a dead stop and smoothly, too. (Smooth is important to long clutch life.)
Once moving I can then fully release the clutch pedal and give the engine as much throttle as I want without having to slip the clutch. Tires might slip depending upon how aggressive I am with the gas pedal but the clutch doesn't slip.
At 120K miles when the transmission was out -- for an RMS repair -- the clutch disc showed no measurable wear. This wasn't eyeballed wear either. I measured the disc friction material wear myself with a depth mic as per the factory manual.
Now with 151408 miles the clutch gives no signs of any problems.
As an aside, while I have never seen the clutch in my Boxster the original clutch still works just fine with over 307K miles on it. Like the Turbo, in fact even a bit better in this regard than the Turbo, the Boxster requires very little RPMs above idle and very little clutch slippage to get the car moving.
I managed similar big miles out of my '96 Mustang GT. At approx. 150K miles the clutch went out but it was not the disc or any of the friction components but the throw out bearing that seized. Except for the Mustang the only other time I had any clutch problems was years ago with an '88 Tempo. The clutch went out -- was slipping -- at 18K miles. There was a known problem with these clutches and the clutch was replaced and when I sold the car (traded it in) with nearly 80K miles on it, 62K after the clutch was replaced, the replacement clutch was fine.
FWIW I've been driving stick continuously since before I could drive legally and I'm 33 now. Never had any other car/truck do this at such low miles. I have been through clutches but usually just did them preventatively at approx 85-100k miles while I was in there doing other maintenance items... and they usually needed it. I can't leave well enough alone!!! I know you guys can identify with that.
Granted the p-car drives fine under normal conditions, but if I hammer it, not all of my power is getting down right after I shift and get off the clutch. It definitely gives up grip at the top of the rev range. Its not the tires- no chirps, no traction control lights. My engine is overpowering my clutch. I know that smell from my teenage years and from years of towing and off-roading in a stick truck.
I'm no Kimi Raikkonen (my personal favorite driver of all time!), but I am familiar with what's good and bad for a clutch. The fact that I am experiencing this is strange to me and that's why I am reaching out to see if it has happened to others. So far, it seems like only one other member has spoken up about a similar situation.
Bottom line: I am not going to blame this on my driving style.
