Bendable tubing for bigger intake
#31
. It works and serves the purpose. The hard piping is so hard to set up even with the engine out because you have no clue where the subframe mount will be in relation to the piping thus requiring often dropping it again and getting to the hard to get to clamps. It really is a pain in the butt.
#32
That's an understatement, Lol. I wanted to fly down to Arizona and choke the life out of the guys that designed the black plastic pipes that Evoms and Speedtech is selling. Luckily you only have go do it once and then you're set for the life of the car. I don't regret it but its a royal biatch to install.
#33
#34
I've learned if something is more expensive, there is probably a reason. Not worth saving a few bucks to waste 10X the time to do something.
#35
#40
thats correct. you would teflon coat the outside of the metal piece to keep heat out
#42
Actually flat black... for a better black body radiator. Teflon or ceramic adds another insulation layer. Ceramic thermal conductivity is not as bad as Teflon, but still an order of magnitude worse than bare metal. The black paint would essentially not change the conductivity. All that said, I'd guess any of these treatments would not make a difference on the air temperature entering the motor.
#43
The problem with flat black is that it will absorb as well as radiate. Biggest thing I'd try to do is limit or insulate physical contact with the motor, air is a terrific insulator. Any contact will transmit heat well. Build the piece from plastic vs aluminum and use plastic tubing to best insulate everything.
Or just eliminate the tubing and run fender inlets lol.
