Bendable tubing for bigger intake
Old 02-18-2017, 03:55 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
hi guys,
iam looking for the bendable tubings for the bigger intake. I want to buy them seperately. Anyone knows what brand/model these tubings are, what size and where to purchase Them?
thx in advance
Old 02-18-2017, 04:53 PM
32krazy!'s Avatar
try patcohydraulics.com they have all manner of bendable tubing
Old 02-18-2017, 06:17 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I tried to do this as the Markski pipes are over priced despite his objections.. I never found a suitable solution and Markski doesn't sell the soft pipes separate. I wound up buying a set of Markski pipes second hand for $400 but there are no markings on the tubes so I still can't find them. They are 2.5 inch. I was going to try this but found the used pipes before I did: http://www.cleancraft.com/50ft-Vacuu...vh-c5025bl.htm
Old 02-18-2017, 06:55 PM
32krazy!'s Avatar
Call patco. They have a large board on the wall with all kinds of bendable tubing sold by the foot
Old 02-18-2017, 08:56 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Any hose wholesale company carries it. 2.5 inch vacuum hose. Very cheap. Probably about 25 bucks or less in hose needed. I buy it all the time for equipment, nothing special.
Old 02-18-2017, 09:57 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Is regular vacuum hose able to withstand the heat an the rubbing?
Old 02-19-2017, 07:14 AM
flewis763's Avatar
you'll need a medium grade vac hose. Typically they are a thicker and former hose. Inside is smoother as well. If you go to a local hose company they should have 3-4 options for you.
Old 02-19-2017, 12:37 PM
infinkc's Avatar
infinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to behold
We use hose like this at my work for running cables in, I will pull up what we use, it's very strong stuff. Looks identical to the markski stuff.
Old 02-19-2017, 11:20 PM
That would be awesome!
Old 02-20-2017, 11:10 PM
911mhawk's Avatar
911mhawk is on a distinguished road
I did the Evoms kit with the larger intake flange welded on too and it's a PITA.
The hard tubes are bomb proof but even when you've test fit them with engine out, they change a little bit after it's in and around the subframe.
If you can do easier method with tubing that won't collapse under vacuum, let us know how it works out.
Old 02-21-2017, 10:29 AM
infinkc's Avatar
I looked it up, its from Mcmaster.
5500K35 is for 2.5"
https://www.mcmaster.com/#5500k35/=16gbiy4
Old 02-21-2017, 10:33 AM
brnrdtns's Avatar
That grey for liquids stuff looks like what we need. Here is a pic of the Markski tubing. One of my tubes was damaged during removal and needs to be replaced.
Old 02-21-2017, 10:36 AM
infinkc's Avatar
Here is a pics of the stuff i linked in 2" looks identical in and out.
ID:	470202   Click image for larger version
Old 02-21-2017, 10:37 AM
brnrdtns's Avatar
That is it for sure. Thanks for the link!
Old 02-21-2017, 01:10 PM
r0nd3L's Avatar
r0nd3L is an unknown quantity at this point
How are you guys planning on connecting the hoses to MAF? Modify the stock merge?
