Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 02-21-2007, 10:04 PM #121
KPG's Avatar
KPG KPG is offline
KPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond reputeKPG has a reputation beyond repute
Quote:
Originally Posted by Al Norton
Kevin,
I guess I'll get my chance in a month or so to see how hard these babies really are for getting any consistency at the strip. I'm used to a 3-speed Lenco and a two-stage rpm limiter for very consistent launches. Well, I was used to it in 1984. :-) Never tried to launch ANY Porsche, much less a tt at the drag strip. Going to go once anyway, just to get some numbers.
From all I read, I'll really have my work cut out for me with a tt. Do you back into the water box and really get a good smoking burn-out in second gear before you go to the line? I would suspect that any tire you choose needs some good heat-build before going to the line.
NO WATER BOX ON STREET TIRES!!! Al, just a quick burnout to clean them off and your good to go. My sweet spot was a 2800rpm launch or thereabouts. I did try a one off banzai 5K launch it was a waste of time and clutch!! Under 3K should work. BTW, most of my 200+ passes at the 1/4 were with Turbo Buicks with automatics so consistency was never much of an issue. Good luck and make sure the Pbox is in there when you run. Kevin
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
TX Mile Results: 201.380mph
60-130.52sec faster thanTopGun
Old 02-21-2007, 10:11 PM #122
heavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond reputeheavychevy has a reputation beyond repute
Kevin,
Al you have to let me know when you are heading to the drag strip I want to be there when you run the car.
Old 02-22-2007, 07:29 AM #123
Al Norton's Avatar
Al Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to beholdAl Norton is a splendid one to behold
Hi D,
I thought we could both go up to Commerce on a Friday evening for one of their "test and tune" events. I understand they do give time slips. Maye we could video each other. I'll definitely let you know when I plan to go.
Old 02-22-2007, 10:05 AM #124
Hi D,
the problem with commerce is that you dont get many runs in. They are usually REALLY crowded, but I'm only 20 mins away here so it's cool. I'll bring the camera.
Yeah that would be great,
Old 02-22-2007, 01:37 PM #125
Al Norton's Avatar
Quote:
Kevin,
Thanks for the tip. I never thought about that. Too used to slicks.
I will carry the P-Box and send you the data. I am having a hell of a time getting my software to do what I want it to. Me thinks the manual leaves a litle to be desired. I tried to lay out the boundaries of an imaginary track and was unable to manipulate the data in the program.
BTW, I'm still searching for a fairly level road to use for the 60-130 runs. If the car runs in the sixes, which I hope it will, about how long a piece of road will I need?
Old 02-22-2007, 07:01 PM #126
KPG's Avatar
KPG KPG is offline
Kevin,
Al, less than 2 tenths of a mile should cover it, but here is some distance data from the 60-130 thread.Hope it helps. The beauty of a really fast car is you are in the danger zone with the local Police that much less than a slower car....Kevin
DMK 6.15sec in 880ft
Markski 6.44 in 917ft
RennTech 6.45 in 926ft
KPG 7.93 in 1166ft
Old 02-26-2007, 12:07 AM #127
We got unstickied for some reason but we'll continue with the updates so keep the info coming.
Old 03-01-2007, 10:37 PM #128
I just weighed the hollow spokes (pirellis) I bought vs Techarts GTS (PS2's) and it was 8lbs per rear wheel and 10lbs per front wheel less for the hollow spokes.
Techarts:
Fronts- 50 lbs
Rears-60lbs
Hollows:
Fronts - 40lbs
Rears - 52lbs
lost 36lbs unsprung just doing this
Old 03-01-2007, 10:45 PM #129
tom kerr's Avatar
tom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond reputetom kerr has a reputation beyond repute
Since different tires may also have something to do with it. There are huge differences between brands. And if you go to track tires they can be 5 pounds apiece lighter!!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
tampavascularsurgeon.com
'02 996TT X-50 SY
'04 Cayenne S
'07 Cayman S SY
Old 03-01-2007, 10:53 PM #130
Quote:
Im thinking I may keep the Hollows on for a while, what tires are great for street and track? I only drive on the weekends in the turbo so miles are not a concern. I'm thinking MPSC or maybe RA1's
My car should be at 3364 right now with 1/4 tank
next is:
LWFW
Clutch Acutator
GT3 Seats
Front Bumper Support
Old 03-01-2007, 10:58 PM #131
geetee is on a distinguished road
At the power level the TT's are, does 20-30lbs of unsprung weight make a difference? I mean on a couple hundred HP car it sure does but it seems like with 500hp, that much unsprung weight wouldnt feel any different. Would it?
99 Carrera2/Aero/Zenith Blue
01 BoxsterS/Black
Old 03-01-2007, 11:06 PM #132
Quote:
Yes when it comes to the wheels and suspension because unsprung wieght (brakes,wheels etc) hurts deceleration and acceleration more than the rest of the car. Any any person who's paying attention to their cars weight will tell you that you lose a little here, a little there to get to a lot of lost weight.
I gained 3 mph (1/4 mile) in my car by taking out a 175 lb passenger. You will see real results for every 100 lbs of sprung weight and every 20 lbs of unsprung weight. And the handling is greatly improved. Weight really takes a toll when you make turns
Old 03-08-2007, 05:03 AM #133
silvershark's Avatar
silvershark will become famous soon enough
Quote:
Originally Posted by jimmer23
Optima Red Top battery = 39.4lbs
Another light weight battery to consider.
Interstate MT-42 = 25.9lbs 2yr replacement 75month prorate
$71.95 + tax 26lbs + savings over stock and no need of a daily maintainer.
01' 996TT 640GT: "Protomotive in Progress"
94' Toyota Supra TT TRD exhaust BPU 450hp
87' 944 Turbo
"The only thing necessary for the Triumph of Evil
is that good men Do Nothing." Edmond Burke
Old 03-08-2007, 02:31 PM #134
tom kerr's Avatar
dont be a wimp...here ya go......
'02 996TT X-50 SY
'04 Cayenne S
'07 Cayman S SY
Old 03-08-2007, 06:18 PM #135
Tom, I have a PC680 as well. Only thing is I may take a overnight trip
and not be able to use a maintainer. And if I am going to carry jumper
cables...it defeats the purpose. I will however use it on track days for
the additional 11lbs savings. + I wanted to spare the chance of embarrasement
asking someone for a jump for my Porsche.
87' 944 Turbo
Reply
Tags
3400, 700, 99336213405, 996, brailleauto, cf, conversion, et, gt, hp, lbs, loss, rwd, turbo, weight, wing
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
