Go Back   6speedonline.com Forums > Porsche (Present) > 996 Turbo / GT2
996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2.
Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 06-03-2007, 03:47 PM #1
KPV's Avatar
KPV KPV is offline
Member of: "The 6 Pack"
KPV will become famous soon enough
Control Arm Ball Joint Removal
Hey Guys,
It has been a while since I have posted. I have been immersed in many other things and am only now getting back to the turbo. I am making some SUBSTANTIAL suspension changes and I have a question.
I need to break the control arm ball joint free from the upright. It is a wedge fit of course and I wanted to know if anyone has a picture or some insight as to the proper puller.
Any help would be greatly appreciated!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Ken
Click Here To See My Cars
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting ...holy ****...what a ride!"
Old 06-03-2007, 04:29 PM #2
dgreen78's Avatar
dgreen78 is a name known to alldgreen78 is a name known to alldgreen78 is a name known to alldgreen78 is a name known to alldgreen78 is a name known to alldgreen78 is a name known to all
You will need a scissor style like this. Make sure to get a quality one with a good course thread bolt.
01' Porsche TT
E.P.L tuned K24/18G, 1bar wastegates, Custom Intercoolers (Bell 4" cores), 75mm TB, 72lb. Bosch Injectors, RSS Y Plenum, Ported OEM headers, Custom A.M.D. "X" Exhaust, Stg. 3 Clutchmasters clutch w/ Aasco LWFW,JIC coilovers, 19" Black Techart Formulas, AEM Methanol kit
Old 06-03-2007, 04:47 PM #3
KPV's Avatar
KPV KPV is offline
Don,
THanks for the input, but that will not work with the 996 turbo. The upright is a one piece casting that the control arm ball joint bolts to. I have considered that type as well as common pullers and none of them seem appropriate to the task. The ball joint must be pulled out of the bottom of the upright. That means a puller must grab the control arm and push against the bottom of the upright in order to pull it off the bootom.
Any other thoughts or suggestions? Anyone?
Ken
Old 06-03-2007, 04:49 PM #4
KPV's Avatar
KPV KPV is offline
Don,
Your scissor type would work if I could use it on the inside of the upright (towards the center of the car), however, the axle is in the way.
Ken
Old 06-03-2007, 08:58 PM #5
PorschePhd is a glorious beacon of lightPorschePhd is a glorious beacon of lightPorschePhd is a glorious beacon of lightPorschePhd is a glorious beacon of lightPorschePhd is a glorious beacon of lightPorschePhd is a glorious beacon of light
Ken,
The version you see will work. You can rotate the arms. I use one almost identical as this one.
Old 06-03-2007, 10:39 PM #6
KPV's Avatar
KPV KPV is offline
Stephen,
It has been a really long time!!!! Good to hear from you!!!
Regarding the scissor ball joint separator, I am trying to do this without removing the control arms. I need to disconnect the uprights from the control arms at all four corners. When you say "rotate the arms", I assume you mean the control arms are disconnected at the chassis allowing them to rotate.
Is there a way to do this without removing the control arms???
And where can I buy that tool?
Best,
Ken
Ken
Old 06-04-2007, 02:50 AM #7
dgreen78's Avatar
I rented mine at my local Shucks (Kragen) parts store for FREE. You just have to get it at the right angle. I used the one in the pic to do my car when I installed coil-overs.
01' Porsche TT
Reply
Tags
996tt, ball, joint
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
