996 Turbo / GT2Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
My radio (power) did not turn on today. The CD still loads and ejects (not sure if that is mechanical or electric). Does anyone have any suggestions or know what fuse the radio is? Would it still be able to take in a CD without power, thanks in advance, ritchie
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
If you had the battery disconnected, then you will need a code for your CDR. It sounds like it is getting power, so something else...what model/year car?
__________________ Statman
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
If it will take a CD it's getting power to drive the servo motor. First guess from my end is that the unit has died. There is a good shop in the Carolina's called SouthEast Stereo I think. They advertise in Panorama. I've used them before and thought they were fair on price and turned the unit around in a hurry. You need the fork/blade shaped pullers to get the unit out and I don't know where you can get them other than the dealer. Maybe some other shop will pull it for you if that needs to be done.
However, If you're going to replace with a factory unit, becker also supplies the same unit for some ferraris and they play MP3s. The downside is that it will say ferrariu when you start the car...
My latest dyno chart 1.2 BAR: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2002 X50. Water cooled Tial GT2860RS, EVO Clubsport Intercoolers, Speedtech Y-Pipe (red), Boost Hoses, 60 lb Injectors, LWFW, RS Clutch, Remus Exhaust, DVs, GIAC FLASH To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , FVD PSS9s, H&R Rear Bar, 19" Champion RG19 Monolites (15mm spacers front and rear), rollled fenders, ROTtec CF Lip and rear window spoiler, Strosek Wing.
