You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Amazing results and price point!! So far this is the most impressive k16 based turbo we've tested!
Quote:
Originally Posted by PorscheCt33
Seems like they're making quite a bit more than standard K16/16Gs to me....
475-500whp / 500-550 ft lbs of torque on pump gas 525-550whp / 575-600 ft-lbs of torque with optional AMS Fuel Upgrade Kit*
I agree, even on a full race gas tune, we haven't seen traps approaching mid 130s with 16gs.
Quote:
Originally Posted by John H.
Insane as in $$$$? Correct me if I'm wrong, but the same size wheels on the hot/cold side with the same AR will produce the same output per given psi. The power seems inline any K16/16G turbo setup if it was boosted to 24psi. That's 6psi higher than other K16/16G dynos. Are the pump gas dynos on par with other K16/16Gs? 475-500whp.
John H
The 16g compressor works very well right up the 1.3 level. This is why we generally don't push that turbo any harder then that pressure.
The billet wheel that AMS has selected for this upgrade is extremely efficient both above and below 1.3.
depends on how much Meth you are tossing at the car but I would rather see the addition of the injectors. Honestly if you are running pure methanol I would imagine the numbers would be right inline with our race gas numbers.
I know some of you were asking about the spool characteristics of these turbos vs. stock K16s. We were able to get a stock K16 car on our dyno for comparison. The results were awesome. It turns out that the AMS Billet K16s spool THE SAME as stock K16s!!! Here is a dyno sheet for your viewing pleasure.
Wow...this modification seems more impressive all the time.
Steve Theodore
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Gemballa reflashed ECU (K16s), GT2 front bumper, 997 SSK, Fikse Profil 13 wheels To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Here is a graph comparing the spool up characteristics of the AMS Billet K16s to the stock K16 units utilizing the stock exhaust. As you can see, they spool exactly the same.
How do we think this compares with Kevin's K16/24s ?
We have not had a K16/24 car on our dyno, so I can't give a direct comparison. I can however give you an educated opinion. Much like the 16G compressor wheel, the K24 wheel is old technology. The most common complaint about the K16/24 upgrade is how hard power falls off in the higher RPMs. With the new billet wheel technology matched properly to the K16 turbine wheel, this is no longer a concern. Without having hard data for the K16/24s I can't give you a definite answer, however my personal opinion is that our billet units will spool quicker and make more power.
