Welcome to 6SpeedOnline.com! |
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
10-23-2009, 07:39 PM
Platinum Sponsor
2007 Porsche 911
The Cure to Run HIGH Boost on Pump Gas
View Our 105% Price Match Guarantee - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1-866-44-VIVID 1-480-966-3040 x222
***WE SHIP WorldWide***
View Our To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. at Texas Mile
Fastest K24/18G Tiptronic To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-23-2009, 07:52 PM
Platinum Sponsor
2007 Porsche 911
Will have install pics up shortly.
10-23-2009, 08:07 PM
Nice to see another tuner embracing water injection!!! Cant wait to see the results from your systems!
EuropeanPerformanceLabs, LLC
Custom Motronic ECU Tuning
203.345.6499
2008 Cayman S : 2003 996tt : 1985 Audi URQ : 03 Mini Cooper s : 09 Mini Cooper
Previously posted as Nerdhotrod
10-23-2009, 08:11 PM
I wanna see more pics of your Blue TT!
10-23-2009, 08:13 PM
Platinum Sponsor
2007 Porsche 911
10-23-2009, 10:26 PM
Tony,
See what you started
John D
(also post as John D, member since 2003)
SpeedTech Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2002 996TT - EPL Tuned K24/18G, SpeedTech X-cellerator crossflow exhaust, SpeedTech Y-Pipe kit, dual pump fuel system (60 lb.), IC's, aerokit
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. (1.24 bar - 104 octane)
Current Mods: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-26-2009, 10:58 AM
Platinum Sponsor
2007 Porsche 911
Vivid Racing has been installing and tuning water/meth injection kits from Aquamist for years and now AEM. We have done TONS of Subaru and EVO's and have extensive background. This is just something newer to the Porsche community. I will have Mitch our tuner dig up some dyno info of cars we have done to show you results.
10-26-2009, 12:05 PM
Hola,
As Dan stated we have been tuning with water injection for some time on Subarus, Evo's, 350z's and a slew of others.
Here are some dyno sheets for some of the cars we have done in the past. We have tested water injection in cars running 87 Octane at close to 30psi just to see the limits of what it is capable of.
Evo X
Evo 9
350z
This is just a couple of them. Water helps us when using 91 octane as we can get much closer to MBT and in come cases can reach it.
Water Injection is a great way of making extra power instead of always running race gas.
Hope this helps,
Mitch Mckee
Vivid Racing
Mitch - VividRacing.com Tuner
1-480-966-3040 x240
11-05-2009, 11:20 AM
what are the pros/cons of the aem vs. the aquamist?
01 Polar Silver 996TT
11-05-2009, 11:24 AM
Platinum Sponsor
2007 Porsche 911
I dont think there are Pros and Cons. We use both here. AEM is just a bit more dumbed down. Simple switch to arm it, then it works off of boost pressure. You can go with the Aquamist HFS6 that has all types of features, but your spending 3times more. Check out all the Aquamist products here - http://www.vividracing.com/catalog/aquamist-m-272.html
Here is the Aquamist HFS6 - http://www.vividracing.com/catalog/a...m-p-61041.html
11-06-2009, 09:24 AM
Quote:
Originally Posted by vividracing
So the aem doesn't have all the safety features the aquamist has? I think that is what most people around here considering it are concerned about.
11-06-2009, 09:44 AM
Platinum Sponsor
2007 Porsche 911
No AEM does, see here - http://www.vividracing.com/catalog/a...k-p-52135.html
"Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error. "
Here is a picture of my JETS installed -
Tags
924, average, boost, classified, gas, high, highest, levels, mbt, octane, pump, switch, turbo  |
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
User CP
Visit our Sponsors
6SpeedOnline.com
Threads:
Members:
