Upgrade Your Stereo System with Diamond Audio
Old 11-28-2008, 03:58 PM
vividracing's Avatar
Diamond Audio Sound Enhancement Package 1 Porsche 996 997 99+
Want to improve the sound system in your Porsche without spending huge dollars? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 1 speaker package to directly replace your OEM door speakers with better quality, better sounding car audio components. This Level 1 kit features the Diamond Audio D3 5.25" component set for the front and rear speakers.
Our new D3 speakers might be the starting point of our coaxial and component range, but they are anything but entry level. We start with the same high density proprietary composite ABS frame found in our D6 convertible systems, add a butyl rubber surround and a graphite injected polypropylene cone and you have the makings of a very good driver. Whether choosing a component or a coaxial system all D3 speakers utilize 1” aluminum dome tweeters. Our D3 component systems use an outboard 18dB high pass/ 12dB low pass crossover with our RAF (Rear Acoustic Fill) circuit so it is easy to add more speakers to your system. You won’t find a better combination of value and performance anywhere.
Level 1 Kit Includes:
Front D353 - 5.25" Component Set
Rear D353 - 5.25" Component Set
$399 Shipped
Diamond Audio Sound Enhancement Package 2 Porsche 996 997 99+
Don't want the cheap products but don't want to spend a fortune on a car audio upgrade? Well Vivid Racing has partnered with Diamond Audio to introduce this Level 2 Sound Enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components and add a 10" subwoofer for bass! This Level 2 kit features the Diamond Audio D3 5.25" component set for the front and rear speakers. Next we add a 10" subwoofer with large rubber surrounds and a titanium finish. To power this package, we include for the front speakers a 300 watt D1 4 channel amplifier. The rear 12" subwoofer is powered by a D1 400 watt monoblock amplifier.
The most dramatic improvement you will ever make to any audio system is by adding a subwoofer. D1 series 2 subwoofers make it easy. These new subwoofers have large roll rubber surrounds and larger motors for better power handling than competing models. They are available in either dual 2 ohm or 4 ohm versions. They work equally well in small sealed or medium vented enclosures. They sound great. And best of all they are affordable.
The D1 amplifiers offer just the right mix of features and power and are a perfect match for our D1 subwoofers. D1 amplifiers feature 12dB per octave high and low pass crossovers and 6dB of bass boost. With both RCA and high level inputs it is easy to upgrade your factory system or build a great sounding all out show stopper.
Level 2 Kit Includes: Front D353 - 5.25" Component Set
D110 10" Dual Voice Coil Subwoofer
D1 300.4 - 300 Watt Four-Channel Amplifier
D1 400.1 - 400 Watt Monoblock Amplifier
Wiring, Hardware, Instructions to connect to a head unit is NOT Included.
Professional installation recommended.
$1069 Shipped
Diamond Audio Sound Enhancement Package 3 Porsche 996 997 99+
If you want the best sound quality and premium car audio products in your vehicle, the Vivid Racing Diamond Audio Level 3 package is your answer. Vivid Racing has partnered with Diamond Audio to offer this Level 3 car audio enhancement package to directly replace your OEM door speakers with better quality, better sounding car audio components, add 2 12" subwoofers, and bring all the power from Diamond Audio's premier amplifiers. This Level 3 kit features the Diamond Audio D6 5.25" component set for the front and rear speakers. Next we add 2 10" D3 subwoofers and to power these a D1 400 watt monoblock amplifier. The D6 front speakers are powered by D3 Amplifier featuring 4 channels and 500 watts.
Something different. That was our goal with the new D6 convertible systems. The bass unit uses a butyl rubber surround attached to the same hard-anodized alloy cone that is found on our D6 subwoofers. This cone is lightweight and has the strength needed for tight, accurate midbass and smooth overall response. The frame is made of a high density proprietary composite ABS and is very rigid. These systems have the unique ability to be used as either a component or a coaxial speaker. Depending on your requirements, the tweeter can be installed separately or mounted directly to the midbass/ midrange driver. With the option of either a 1” silk or aluminum dome tweeter you can choose the type of sound that fits your musical taste. Our model specific crossover with RAF (Rear Acoustic Fill) allows an additional pair of speakers to be added without adding another amplifier. The new D6 speakers are the definition of flexibility.
Like our D3 amplifiers, our D3 series 2 subwoofers are the definition of value and performance. With large 2.5” dual voice coils, available in 2 ohm or dual 4 ohm, beautiful polished back plates and dual spiders, with woven tinsel leads, these subs have features found in much more expensive models. All D3 series 2 subwoofers handle up to 400 watts RMS. Our proprietary aluminum dust cap pulls heat away from the voice coil so they play louder, longer.
The perfect blend of value and performance, is our combination of the D1 and D3 amplifiers! With a newly designed heat sink that features 25% more aluminum than the previous generation, these amplifiers are capable of considerably more power than ever before without increasing their overall size. On board 12dB per octave continuously variable crossovers and up to 12dB of bass boost make them very flexible.
Level 3 Kit Includes:
Front D652s - 5.25" Component Set
Rear D652s - 5.25" Component Set
S104 - 10" Dual Voice Coil Subwoofers
D3 500.4 - 500 Watt Four-Channel Amplifier
$1989 Shipped
Vivid Racing has put together these car audio packages to enhance your vehicles sound system from the stock quality. We have chosen to partner with Diamond Audio, a Arizona based manufacturer of speakers, subwoofers, and amplifiers. Diamond Audio has several different levels of products to give your vehicle a crisper, cleaner, and more "thumping" sound. Each one of our audio packages includes the direct replacement sized speakers to upgrade your vehicle. We have spec'd out the best size speakers and/or amplifiers to work in your vehicle to produce a great sound system.
You can view all our Car Audi Kits Here - http://www.vividracing.com/catalog/diamond-audio-m-454.html?class_9=-1&my_type_id=8&class_8=38
Old 11-28-2008, 05:34 PM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
Are these kits designed for 911's with factory door speakers? I only have speakers in the dash and the rear. 4 total.
Old 11-28-2008, 05:38 PM
Correct these replace the factory door speakers.
Old 11-28-2008, 06:21 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Very cool. Is the Level 1 kit something a non-professional could do? If not, how many hours to install?
Old 11-28-2008, 07:19 PM
Yes level 1 requires you to pop off the speaker covers, unbolt the speaker, unclip the speaker wire, then install new ones. I will try next week to get install pics!
Money2536
01-19-2022 08:22 AM
audipwr1
09-25-2021 01:31 PM
Superaudiofreak
06-10-2016 02:04 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
00aston
08-24-2015 09:29 AM
Quick Reply: Upgrade Your Stereo System with Diamond Audio
