996Previous model naturally aspirated Porsche 911 community. Discuss C2, C2s, C4, C4s, Targa and Cabriolets. Sponsored by Spec Clutch
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Hey guys,
Having a coolant leak issue. Wondering if swapping out the coolant reservoir tank would be the 1st step to remedy most cases of coolant leak or is it more involved. [IMG]file:///Domain/wmcnet.khny.net/Users/JLing/Desktop/997COOLANGJUG4.jpg[/IMG]
996 coolant tanks are notorious for failing; is yours yellow? If so, you most likely just need a new tank (I think it's a revised part). The tank, ideally, is white.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - K16/16G
I had a coolant tank leak, a couple of months ago, and yes, mine is a 2002 also. Also buy a new radiator cap. I swapped mine out in about 1.5 hours. Undo the hoses and the coolant level switch first. Place a small hydralic floor jack with a 2X4 across the length of the oil pan, undo the 2 nuts holding the engine in, lower the engine, then wiggle tank out, (it's a real Bit$$# to get out), harder to wiggle new tank in. Once new tank is in, raise engine, put your 2 nuts back in, attach hoses, coolant level sensor, and fill up with antifreeze, make sure you hoses are clamped in good.
2002 Porsche 996 Carrera Coupe (Arctic Silver) B+M SSK, IPD Plenum, EVOM CAI
Thanks guys, I will have to take a good look to see where leak is coming from and color. I've been reading from older posts that ID'd the res tank as usual culprit. Scuba, should i see cracks?
There wasn't a crack, but a very small pinhole leak underneath the inside on the tank in the middle, basically if you look at the top on the tank where the pressure release valve, it's under there, to the outside of tank.
If you PM, with a email address, I'll take a picture for you, and send it you
On the new tank, they reinforced that area.
Reason: additional info
Had mine leak 2 weeks ago. One night, I walked into the garage to discover a green puddle and it appeared to be dripping from my driver's side exhaust. It was the coolant tank, had a small barely visible crack due to age and heat. Dealer charged $560 to fix it. Fortunately my extended warranty took care of most of it.
02 C4 Convertible Artic Silver/Black
6 speed Aluminum Gauge Rings and pedals, Kenwood DNX 7100 with Nav, bluetooth, CD Changer, backup camera, Gentex (amber)auto dimming mirror w/ homelink and compass, Rain sensor, V1 hardwired, Smart /Remote top, Fabspeed exhaust and intake, Softronic Flash and GMG headers
