Oil in Coolant
Old 08-02-2010, 07:20 PM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
Oil in Coolant
Well this SUCKS.... I've only had my '00 996 C2 for just under 2 months and now I just realized that I have oil in my coolant which is never a good sign.
*So does this mean rebuild?
*how do I isolate what the problem is?
*And does any one know of any reputable mechanic in San Antonio, TX or nearby areas?
Old 08-02-2010, 09:36 PM
white99c2's Avatar
white99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of light
It sounds like a head gasket. You need to have the coolant system pressure tested ASAP.
Old 08-02-2010, 10:19 PM
Fozzybear's Avatar
Fozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of lightFozzybear is a glorious beacon of light
It could be a lot of things, including:
- head gasket
- intermix
- cylinder header
- cylinder sleeve
Whether a rebuild is in order will depend on what the issue is.
Old 08-02-2010, 11:49 PM
Grant P's Avatar
Grant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of light
Old 08-03-2010, 07:02 AM
thanks grant, Dharn was the 1st person I contacted yesterday.
Old 08-03-2010, 08:11 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Could be a head gasket, but if it is it will be the first one I have heard of personally, and I have talked with a lot of owners with the intermix. I still believe that the most common source is the cracked cylinder head, but I might be biased.
Old 08-03-2010, 11:55 AM
Wicked 996's Avatar
Wicked 996 will become famous soon enoughWicked 996 will become famous soon enough
we can all guess - i would do a pressure test and a leak down and see what you're up against.
Old 01-06-2014, 05:48 PM
In2Deep's Avatar
In2Deep is on a distinguished road
Looking for a shop in So. Cal to fix Intermix. Does that require a full rebuild or just fixing the cracked head. 2000 C2 95,000miles. IMS Retrofit done, New Fly heel, Clutch and 90 k mile service done less then a year ago. Pancake batter in Reservoir. No coolant on dip stick... Car ran perfect all the way home. Haven't moved it since.. I was looking for a place that could pull the engine and get to the heads. And clean out the cooling system. Thanks .....
Old 01-07-2014, 06:28 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Have them check the oil coolers as well.
Old 01-13-2014, 10:08 PM
call Jason, he is local to so. cal. 714-794-4276
you can mention me
-Jesse
Saint Ari
01-17-2022 09:22 PM
Rguy
04-12-2020 11:11 PM
ECS Tuning - VW
09-02-2015 01:19 PM
Quick Reply: Oil in Coolant
