Installed Double Din, now alarm problems, HELP!?
Hi all. I did a search but couldn't find anything close to my problem...or not my problem fully...
Here is the deal.
Had a double din unit custom installed from a reputable shop. Everything works great, except when I lock the doors sometimes I get a beep after the 2 flashes of the lights.
I did some searching here and that means something isn't protected...all doors are closed and the center console is closed and tight.
Heres the other issue - sometimes randomly after a few minutes my alarm is going off with nothing around to even get it going. I did another search and I read sometimes you ahve to do something to the ground wire for the alarm when installing? If not it thinks you are pulling out the stock stereo and this is what is causing the alarm to go off?
So sometimes it beeps when I lock, and then the alarm goes off randomly. Other times it locks without a beep but the alarm still goes off randomly.
Any thoughts? I want to take it back to the install shop and they will attempt to fix it but I need some help in ideas on what it could be?
I don't mind the beep when I lock, it just doesn't happen all the time and I am more concerned about the alarm going off when I am in a store or just randomly in my garage when neighbors can hear it.
Many thanks in advance!
Here is the deal.
There is a wire that was attached to your original head unit and it should now be grounded. It probably isn't which is telling the alarm system that the head unit was messed with.
from another website: "alarm system has a small contact switch located to the left side of the radio compartment that detects removal of the radio. In order to prevent the alarm from repeatedly going off, you need to connect this wire (brown / blue) to ground."
socialpro
Cayenne 958
05-18-2016 09:58 AM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
