Weird noise/front end
Old 04-27-2013, 09:48 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Ok, I know this has been discussed before but I think I have something different, I hope.
My C4S has developed a strange rattle up front when going over bumps (especially smaller ones), happens on both the up and down (like rattle rattle rarrle rattle). Now for the weird part, it doesn't happen when you first get going, or when your driving, only at low parking lot type speed. Any thoughts?
Old 04-27-2013, 11:43 AM
kent996's Avatar
kent996 will become famous soon enough
I guess the problem is the strut mount of the front suspension. you may take the cap off to check if there is any movement.
Old 04-27-2013, 12:17 PM
Dennis C's Avatar
+1
It sounds like your strut mounts and strut bearings need to be replaced. I had mine replaced back in January of 2011 for similar symptoms at 96,587 miles. I had the work done at a Porsche dealer. The total with parts and labor was: $1,424.36.
Old 04-29-2013, 09:21 AM
FLA996TT's Avatar
I'll check it out, I looked at it yesterday and there was no sign of wear anywhere, even the bearing looked nice and intact. I'll pull the cap off later to see if the top nut may be loose.
But you know, the noise sounds lower and closer to the front of the car.
Old 04-29-2013, 10:36 AM
xxaarraa's Avatar
xxaarraa is on a distinguished road
I had a very similar problem, but it was so outlandish that I don't think it is the same issue for you. Both my front a-arm bolts had rattled and fallen off. The a-arm is still held on by the rear bolts, but this caused significant rattling while going over bumps as well as steering wheel shake while slowing/braking.
Old 04-29-2013, 11:08 AM
FLA996TT's Avatar
I went home at lunch and looked at the struts from the underneath, and everything looks good, in fact almost new! In fact the strut stop, stop plate, and bellows all looked new as well. I mean no dirt and still had writhing on them.
I'll have to look at the sway bars etc..
Old 04-29-2013, 01:26 PM
swaff's Avatar
swaff has a spectacular aura aboutswaff has a spectacular aura about
This probably isn't it, but you haven't recently put anything in the trunk up there that might be moving around when you hit bumps have you? Hope you get it sorted out soon!
Swaff
Old 04-30-2013, 06:10 AM
FLA996TT's Avatar
No, but this did cross my mind as well, I'll take the little tool bag out and see. Hey, you never know!
Swaff
Old 05-06-2013, 07:50 AM
FLA996TT's Avatar
Ok, well I looked at the struts up and down and everything seems normal, no cracked bearing all tight, in fact as I mentioned before, they almost look ner, no rust to signs of warn rubber....So, it must be something else, like sway bar, drop link, I'll keep looking.
Old 05-06-2013, 09:02 AM
GOB's Avatar
GOB
GOB is offline
GOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud of
On my ex C2, it was the drop links. They looked fine, but after changing them, the noise went away.
Old 05-06-2013, 09:17 AM
FLA996TT's Avatar
Gotcha, I'll have a look...thanks
Old 05-06-2013, 10:59 AM
alpine003's Avatar
x2
Also if the droplinks aren't fully broken, it's sort of hard to check with them bolted up. You would need to unbolt one end at least to move them and check for any looseness or rattle.
Old 05-06-2013, 12:39 PM
FLA996TT's Avatar
Ok, thanks. I think I'm off to the shop and let them have a look see. The strange thing is you don't hear it until the car's been driven a while, like going out of the neighborhood no noise, returning you hear it, and never while driving around at normal speeds..?????
Originally Posted by alpine003
x2
Old 05-08-2013, 10:40 AM
swaff's Avatar
Did you get a prognosis from the shop yet?
Swaff
Old 05-08-2013, 11:25 AM
FLA996TT's Avatar
No, I've been lazy over the last couple of days I'll do it in short time though. I'll let you know what I find out.
Swaff
Quick Reply: Weird noise/front end
