Howling help???
Howling help???
I have a 2003 996 C2 cab with manual trans and 17K miles. Sometimes while sitting at idle with the car in neutral, I hear a howling sound which appears to come from somewhere behind the gas filler door compartment. When I open the gas filler door, it REALLY sounds like it is coming from right behind it. I tried loosening/tightening the gas cap and that doesn't help at all. If I give it a little gas it goes away and sometimes the noise stops suddenly on its own...any thoughts? I can't remember if it only happens when it is cold or not.
Thanks,
Allan
Thanks,
Allan
I'm no specialist on these cars but I do know the evap canister is behind that area and there may be vacuum tubes associated with it. By how you describedthe noise it sounds like a vacuum leak at that area. Pull the front wheel and wheel house and start it up on jack stands to see if you can locate the leak.
