my first 996 maintenance
I did my plugs, fuel filter and oil the other day . Not too bad I must say very comparable to the boxster which i have performed this task many times on . The plugs are harder than the boxster it is a tighter space for sure. I was happy to find no leaky tubes and all 997 coil packs . For the fuel filter you have to get the car up a little higher as the filter is about dead center in the car. you got to be careful with the dripping gas . The oil change was an oil change . I did change from a 0w to 5w hoping to quell some chain noise on start up but no change there . I got motor mounts this weekend and hopefully that will be it till the spring.
Good work! Sounds like you're getting some things done and DIYing allows you learn a little more about the car as you have.
You'll find the engine mounts to be straight forward. Here are some instructions we wrote to assist or provide another perspective as you tackle the project:
Replacing Your Engine Mounts
Congrats on your first maintenance experience with your 996!
Mark/Pelican Parts
Mark/Pelican Parts
Feelgood MD
03-24-2016 09:35 AM
NYoutftr
12-02-2015 06:31 PM
ECS Tuning - VW
09-02-2015 01:47 PM
