LED 3rd Brake Light - Resistor Needed?
Old 08-06-2014, 12:13 PM
996_911C2_Dhru's Avatar
996_911C2_Dhru is on a distinguished road
I already have LED Tail Lights that came with resistors and all work fine. I want to update the 3rd brake lights (2) to LED as well. Do I need load resistors for them? And if so, what specification?
From the ebay listings I see them packaged with 2 25W resistors PER brake light.
Just wanted to confirm.
I've search the forum but was not able to find an answer down to the specifics.
Thanks for the help.
Old 08-06-2014, 02:16 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Get with the Pelican Parts
Old 08-06-2014, 04:25 PM
alpine003's Avatar
No resistor needed for 3rd brake light
Old 08-06-2014, 05:09 PM
MkC2S's Avatar
mine works fine w/out the resistor
Old 08-06-2014, 05:16 PM
Sleek996's Avatar
Sleek996 is on a distinguished road
I was looking to do the LED too, did you guys go with the ebay one or?
Old 08-07-2014, 07:33 AM
alpine003's Avatar
There are only two manufacturers, Spyder and Depo. It doesn't matter where you get them from. Depo makes the highest quality aftermarket lights and a bit more expensive. The Spyders are cheaper but also cheaper quality.
Old 08-07-2014, 10:54 AM
Thanks for replies.
Just a point of clarification. I already have the Depo LED tails and they come with resistors and work fine. The question I had is when combining these with two LED 3rd brake lights (Wing and Trunk) would I need a resistor for the 3rd brake lights. Seems like the answer is still no. Will try without. Worst case scenario is I throw a light and have to add a resistor! I guess when you combined LED Tails with brake lights you start to drop the current pretty low. Hence the possible need for more resistors. I will let you know my results
Thanks all.
I went ahead and did the License Plate lights too. $1.40 per light.
Old 08-13-2014, 11:46 AM
33jacket's Avatar
33jacket is on a distinguished road
third brake light operates off the resistance of the other two side lights...so basically if you your rear tailights have the resistors or are OEM bulbs then you should be fine without needing a resistor
COBB Tuning
01-29-2022 09:42 AM
The_Ruski_Driver
10-25-2015 08:40 PM
Fadi
08-21-2015 03:43 AM
Jeff1smith
08-19-2015 09:41 PM
Quick Reply: LED 3rd Brake Light - Resistor Needed?
