Removing seat heater switch batwing
Just checking before I break something. Referring to the pic below, I need to remove the batwing with the blue line pointing to it. I don't know if it matters, but I removed the torx that is hidden behind the gusset in the pic below. Does that just snap out?
Batwing just pulls off as b2sc said. I moved my heated seat switches
to the 2x blanks behind the ashtray/windows switches. Much easy to
get access to than behind the gear change lever. Easy DIY if you can
use a soldering iron.
Somy
04-02-2016 06:05 PM
