3rd break light LED Aero-kit rear spoiler
Hey you guys, so I replaced my tail lights to Depo LEDs, but I can't find the way to also change the third brake light, Any one of you know where I can find it or the part number?
Thanks,
Thanks,
I will try to find it, I thought it needed to be replaced when I first got the car, but it was only the connection, it needed to be cleaned and reattached and have not had a problem since.
The 996 third brake light is not LED from the factory. It uses a row of incandescent bulbs.
There are several aftermarket options available for LED replacement and it's a very easy thing to do.
Could you please be able to see if you can post the after market replacement? Because I am not sure how to do a search on them. I am not been able to find the ones that will fit on the rear spoiler.
Clearly, I know that but is it the same fitting? I have a rear spoiler, plus I don't have the part number.
I was not aware it is the same part number as the standard rear deck brake light.
It looks too wide on my Factory Porsche Wing to fit inside regular opening.
Franco, Is your wing factory Porsche, it will be coded under front hood?
I know the aftermarket wings will fit regular light.
Beautiful car by the way and the color I always wanted but could not find.
As for the LED units, I don't recall where I bought the one for my 996. I searched online and found one.
I got my 3rd light LED from Del Rey Customs
Perfect fit Zero problems
http://delreycustoms.theshoppad.com/...ents-pre-order
