Need help with alternator removal.
Hello all
Trying to remove alternator. Took out bolts and tapped on the one with the pulley after a couple of turns. No luck in removing the alternator after bolts came out. Seems to be stuck where the pulley was. Am I missing something?
[QUOTE="edes300;4570938"]Hello all Trying to remove alternator. Took out bolts and tapped on the one with the pulley after a couple of turns. No luck in removing the alternator after bolts came out. Seems to be stuck where the pulley was. Am I missing something? I can get it to clockwise rotate a little but that's it.
kent996
10-19-2016 01:49 AM
