Knowledge Base Thread - Do NOT create new threads..post in this one
Very common problem on the 996TT - replacing diverter valves.
https://www.6speedonline.com/forums/...narrative.html
fuel pump trouble, hose splitting, how to change it and different pictures with explanation
https://www.6speedonline.com/forums/...-pictures.html
Alternator DIY Remove and Replace:
https://www.6speedonline.com/forums/...e-replace.html
Brake Pad and Disc DIY Remove and Replace:
Head Light Switch Remove and Replace:
this thread is a great idea- would be nice if we could some how make an index!
RWD Conversion DIY:
https://www.6speedonline.com/forums/...996-turbo.html
More RWD info will be added to this post....
GT2/3 uprights and suspension conversion:
https://www.6speedonline.com/forums/...-uprights.html
DIY - Replace Coolant Reservoir 996 TT - https://www.6speedonline.com/forums/...reservoir.html
DIY - How to replace your Alternator - With Pictures https://www.6speedonline.com/forums/...-pictures.html
997.2TT turbo intercooler data and install on 996TT:
https://www.6speedonline.com/forums/...olers-wow.html
disassemble/reassemble multi price rims videos + how to make measurements
Here, this link to videos that will help everybody on how to disassemble/reassemble multi piece wheels, as well as how to measure offset etc.
http://www.ccwheel.com/technical.php
It's pretty basic, and the principal is the same regardless of what brand of rims you have, but saying that if you watch the videos and it still looks difficult to you don't do it. An unattended leaky silicone gasket will destroy expensive tires in two seconds.
But doing it yourself always gave me a sense of pride
A little FYI about spark plugs....
I didn't know this and thought it would be good info.
NGK BKR7E spark plugs are manufacturer part number: 4644
Bosch FR6LDC spark plugs are manufacturer part number: 7410
These are both the ideal plugs for boost over .8 bar from most tuners and are available at most local auto parts stores.
Precision Porsche Intercooler Duct Splitters - http://www.vividracing.com/catalog/p...?cID=10&pID=56
