Knowledge Base Thread - Do NOT create new threads..post in this one
#61
RS LWFW conversion parts list
***Edited to correct pressure plate bolt part number***
Clutch guide tube: 950 116 813 30
Guide tube screws: 900 270 055 02 (2 ea)
Starter ring gear: 964 114 143 31
Throw out bearing: 944 116 080 01
Flywheel bolts: 928 102 151 01 (9 ea)
Flywheel: 964 102 239 31
Pilot Bearing: 931 102 111 00
Pressure plate bolts: 900 067 103 02 (9 ea)
Note:
The following is added for the addition of the lightweight RS pulley. Porsche released a TSB on the 997 GT3 related to fix an issue with this stock weight pulley coming off when the lightweight flywheel is installed. So far I have not personally heard of this happening on the 996TT, but I personally would at least re torque and loctite the pulley bolts for good measure.
996 102 017 95 Crank pulley
999 025 174 02 Washer
996 102 550 80 Bolt
Note:
996 102 550 80 Bolt
FYI, PPlate bolt 999.510.015.02 is 5mm too short and will not work.
ModBargains
Ferrari Vendor Classifieds
10-13-2015 03:47 PM
ModBargains
Lamborghini Vendor Classifieds
10-13-2015 03:47 PM
ModBargains
Maserati Vendor Classifieds
10-13-2015 03:46 PM
ModBargains
BMW Vendor Classifieds
10-13-2015 03:46 PM
ModBargains
Audi Vendor Classifieds
10-13-2015 03:45 PM
