996tt Knowledge Base
Knowledge Base Thread - Do NOT create new threads..post in this one
Rating: Thread Rating: 2 votes, 3.00 average.
Old 11-29-2010, 08:17 PM
GT3 Chuck's Avatar
Administrator
Please do not create new threads...post your link in this thread...
here are a few examples to get it all started:
Link to 996tt Shop Manuals: Ok guys-here is the link to the shop manuals Ed. This link seems to longer function
Link to Short Shift Kit Install: https://www.6speedonline.com/forums/...tal-996tt.html
Link to Brake Info: https://www.6speedonline.com/forums/...h-fiction.html
Suspension Alignment Thread: https://www.6speedonline.com/forums/...lets-chat.html
Suspension Made Simple: https://www.6speedonline.com/forums/...de-simple.html
Road Racing Thread: https://www.6speedonline.com/forums/...car-track.html
Official 60-130 Thread: https://www.6speedonline.com/forums/...mile-list.html
Turbo Weight Loss Thread: https://www.6speedonline.com/forums/...urbo-list.html
Brake Bleeding Solution: https://www.6speedonline.com/forums/...-solution.html
DIY Accumulator Thread: https://www.6speedonline.com/forums/...or-w-pics.html
Old 11-29-2010, 09:15 PM
VAGscum's Avatar
Link to EVOMS Clutch Slave conversion instructions (see post #12):
https://www.6speedonline.com/forums/996-turbo-gt2/156489-need-evoms-gt2-clutch-conversion-instructions-help.html
Alternator voltage regulators:
Wood Auto
part number is VRG46444-~$80 (not from dealer)
Bosch regulator
Bosch interchange part number: F00M-145-350 (which supercedes PNs: F-00M-145-200, F-00M-145-209 and F-00M-145-225)
Porsche part number: 000-043-206-37-M14
Bosch catalog with information: http://www.bosch.co.nz/content/langu...pare_Parts.pdf
IAT
part number: 09115
Here is a link with that info:
http://www.iat-usa.com/Regulators.pdf
Link with info: https://www.6speedonline.com/forums/...regulator.html
Link to DIY to replace Alternator Voltage Regulator(AKA Generator Circuit Control Module): http://www.renntech.org/forums/index...rcuit-control/
Bosch Bypass Valve (A cheap and reliable upgrade)
Part number 06A-145-710-N- $50
The 710N is a VAG part that has proven itself to be reliable up to ~20psi of boost and doesn't require lubrication. This part is available at at any VW or Audi dealership. They have updated the valve even more which will change the "N" to another letter, but as long as it is an"N" revision or higher it is a good part.
Old 11-29-2010, 09:37 PM
VAGscum's Avatar
Link to GBox 2nd gear popout fix install:
http://www.renntrack.com/forums/show...278-Detent-DIY
Link to FPR replacement DIY:
http://www.fsrpca.org/forum/5-carrer...o-fpr-diy.html
Link to cheap stock exhaust mods:
https://www.6speedonline.com/forums/...ler-996tt.html
Note: This mod is only for making your stockexhaust louder.
Bosch Alternator replacement:
part number WO133-1646737-~$310 (not from dealer)
Old 11-29-2010, 10:13 PM
VAGscum's Avatar
Good info on intermediate shaft noise and chasing the cause:
https://www.6speedonline.com/forums/...aft-noise.html
Old 11-29-2010, 10:55 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Tranny oil cooler install.
https://www.6speedonline.com/forums/...996-turbo.html
Old 11-29-2010, 11:16 PM
cjv's Avatar
cjv
cjv is offline
Moderator
How to disconnect PSM
On driver's side you have a plastic cowl/cover with a hole for brake fluid and this same plastic cover holds the interior light.
Remove this cover.
Now you see the brake master cylinder and the ABS unit. Next to the ABS unit, under the master cylinder there is a cylindrical pump, this is the pre-charge pump. Unplug the power connector (fairly thick black and red cables supply power to this one).
Here are the pictures. https://www.6speedonline.com/forums/...ml#post2853373
Old 11-30-2010, 12:35 PM
vividracing's Avatar
How to Install a Precision Porsche GT2 Front Bumper - https://www.6speedonline.com/forums/...umper-why.html
Why a Colder Spark Plug is Better IMO - https://www.6speedonline.com/forums/...ant-996tt.html
Spark Plug Installation Basic DIY - https://www.6speedonline.com/forums/...diy-guide.html
How to Flash Your ECU - www.vrtuned.com/installation
How to Install Brembo 2pc Rotors, 996TT or 997TT - http://www.vividracing.com/blog/proj...d-on-vr-997tt/
Old 11-30-2010, 04:06 PM
bbywu's Avatar
Old 11-30-2010, 08:54 PM
John@SpeedTech's Avatar
CEL trouble code List
List of diagnostic trouble codes: http://www.speedtechexhausts.com/page23.html
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
info@speedtechexhausts.com
Old 11-30-2010, 10:08 PM
bbywu's Avatar
World's greatest primer on turbocharging:
http://www.turbobygarrett.com/turbob...rbo_tech_basic
Old 12-01-2010, 05:43 AM
VAGscum's Avatar
Good info on why you should use 5w40 vs 0w40 oil-Read the whole thread!
http://forums.rennlist.com/rennforum...-question.html
Old 12-01-2010, 06:58 PM
bbywu's Avatar
DIY oil change for the m64 block - identical to the 997TT/GT2 except you may want to drain the turbochargers as well.
https://www.6speedonline.com/forums/...-m97-70-a.html
Old 12-02-2010, 08:03 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
How to change out parking lights: https://www.6speedonline.com/forums/...light-led.html
How to remove stock spoiler for turbo: https://www.6speedonline.com/forums/...t-spoiler.html
How to install Precision Porsche rear TA skirts: https://www.6speedonline.com/forums/...s-install.html
How to install TA front: https://www.6speedonline.com/forums/...nt-bumper.html
Old 12-02-2010, 12:16 PM
raineycd's Avatar
Old 12-03-2010, 11:14 AM
bbywu's Avatar
Not sure if it is kosher for non dealership/service departments to use this, but it's out there:
https://techinfo2.porsche.com/PAGInf...?Type=GVOStart
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
Quick Reply: Knowledge Base Thread - Do NOT create new threads..post in this one
