996tt Knowledge Base
Wrap exhaust?
Old 11-17-2016, 10:24 AM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Wrap exhaust?
Removed original muffler/cats because previous owner modified muffler. Original muffler was fit with tin heat shields. Have purchased a set of aftermarket mufflers/cats. Would there be any advantage or reason to wrap these as there are no heat shields on or with them.
Old 11-17-2016, 12:00 PM
C1Forged's Avatar
C1Forged will become famous soon enough
Yes. Wrapping exhaust pipes next to sensitive areas of the engine bay such as intake piping, intercooler piping, oil/coolant lines will all help keep down temperatures from radiant heat soak.
Old 11-17-2016, 01:16 PM
bushrat's Avatar
Thought it might be a good idea, thanks for taking the time to respond.
Old 11-29-2016, 12:36 PM
32krazy!'s Avatar
almost the entire exhaust is at the back. heat really doesnt effect any of the motor i/c or intake systems. wrapping it will do do almost nothing but maybe insulate some noise. headers are already double wall and dont need a wrap
Old 11-29-2016, 01:01 PM
bushrat's Avatar
Thanks for taking the time to respond. Two responses... opposite opinions, interesting.....
Old 11-29-2016, 08:46 PM
32krazy!'s Avatar
the entire back end of the car already has a heat shield. the sides of the exhaust have heat shields to protect the i/c headers are double wall. porsche already thought of a way to ensure longevity of the components close to the exhaust
Old 11-30-2016, 12:39 AM
bushrat's Avatar
Took all those off when I dropped the engine/transmission. Stock muffler had 4 heat shields bolted to it, aftermarket mufflers(Max speed) have none, that's why I wonder weather they should be wrapped. Also noted that some aftermarket cats have tin shields as well, these don't.
Old 11-30-2016, 06:44 AM
32krazy!'s Avatar
You should a large dimpled heat shield that. Runs the entire width of the rear not attached to the exhaust but to the body. Same for behind the i/c area
Old 11-30-2016, 10:17 AM
bushrat's Avatar
Have both
