| 996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing |
Thread Tools | Rate Thread | Display Modes |
Uneven ride height
I bought my car used from a dealer here and after I bought it I noticed the ride height was uneven (the entire right side of the car was about 'a finger' higher). I never really thought anything of it until this week when I had my PSS10's installed. While installing them my mechanic told me there was a new sub-frame piece in the rear. And right now with both front coilovers adjusted to the same spot and both rear coilovers adjusted to the same spot the car is (surprise) one finger higher on the right side.
Any clues as to what can be going on? The panels haven't been replaced so hasn't had any body damage but I'm guessing the frame is tweaked some how, although the car drives just fine. I can adjust the coilovers to make it look even but that's only an atheistic fix and besides the point.
| Sponsored Links | ||
Quote:
2004 Carmon Red Cab + Tip EVOMs GT660 |
Same expereince for me with both JIC's and PSS10s, the right side (passenger side) are always 1-1.5 finger gap higher comparing to the left side, esspecially the rear. Strange... I have lowered cars for my entire life, but on the TT, the difference is huge. I have adjusted the coilovers to balance the height. I think corner balance is the way to go to correct weight distribution.
how low are your fronts? i have them as low as they'll go and there's still a two finger gap on the right side..
slightly less then 1 finger gap all arround, with max at the front.
thats how my front left is. should i adjust the coilovers to make it as even as i can then have it corner balanced?
Sometime, you have to choose between corner balance and even ride height. Just take your car to a good corner balance/alignment shop and let them educate you.
I had similar issue with my PSS9, the left rear was 1/4" higher than the right rear. We had to lower the left rear coil about 1/2" to lower the car 1/4" on that corner. It's not exactly a 1:1 ratio as to coil and ride height difference as the weight distribution within the car isn't exact. That's why people corner balance. For me, I was happy just to even the car out so I don't have to look at the uneven height. Driving wise, I cannot feel the difference before and after adjustment.
John in Norcal '01 996 C2 Tip Black/Graphite Grey (100% stock daily driver) '01 996TT Arctic Silver/Natural Grey (SOLD To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ) (IA Stage IV, Sachs Stage 2 clutch, Ruf PSS9, Cargraphics exhaust, Reus System, 19" Kinesis K19) |
ok so seems normal enough. i just toyed with it and its almost even all around just need a major alignment now. thx guys.
I did PSS10 and also had to have them readjusted after 1,000 miles to even out the ride height. Only the right rear ended up being about 1/4" higher. Fronts are all the way down with about a finger width fender gap. Rears are about 2/3 down also with a finger width fender gap.
03 996TTX50 Coupe Black 05 AMG C55 Silver 06 X3 Silver In loving memory of my bank account 95 993 RS look Couple Black 85 911 Coupe Guards Red 83 911 Cab Artic White 80 911 Coupe Met Black 78 911 Coupe Cashmere 99 AMG C43 Black 97 M3 4dr Silver 95 325i Black 85 318i Black (notice no new cars between 85-95 that's was being married does to you) |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
