| 996 Turbo / GT2 Turbo discussion on previous model 2000-2004 Porsche 911 Twin Turbo and 911 GT2. Sponsored By Vivid Racing |
| View Poll Results: Please check which year vehicle, and which shifter you had when the problem occurred | |||
| 2001 TT / stock shifter |
7 | 28.00% |
| 2001 TT / SSK |
2 | 8.00% |
| 2002 TT / stock shifter |
4 | 16.00% |
| 2002 TT / SSK |
1 | 4.00% |
| 2002 TT 'X50' / stock shifter |
2 | 8.00% |
| 2002 TT 'X50' / SSK |
0 | 0% |
| 2003 or newer TT / stock shifter |
5 | 20.00% |
| 2003 or newer TT / SSK |
2 | 8.00% |
| 2003 or newer Turbo 'S' / stock shifter |
0 | 0% |
| 2003 or newer Turbo 'S' / SSK |
2 | 8.00% |
| Voters: 25. You may not vote on this poll | |||
Thread Tools | Rate Thread | Display Modes |
#31
Thanks for the posts, guys. The more data we have the better. Thanks again.
Scott 2006 C6 Z06 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Bone stock - 453 rwhp 60-130: 7.86 (2-shifts) Protomotive PE1000R 996TT (SOLD) 889 rwhp Best 1/4 Mile ET/MPH: 10.45/148 60-130: High-boost: 4.67 (2 shifts, 1.6 BAR, 116 octane) Mid-boost: 5.19 (2-shifts, 1.3 BAR, 100 octane) Low-boost: 5.52 (2-shifts, 1.1 BAR, 93 octane) |
| Sponsored Links | ||
#32
01 with oem shifter..had 2nd gear issue around 30k miles. Installed the B&M SSK later and the problem remained the same. Zero track time.
#33
Damm crazy guys!! I see its getting to be a common thing. Thanks god (knock on wood) mine with SSK never had an issue, goodluck guys!
Martin
02 RUF R-GT2 590+ Track Beast To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 07 997 GT3 *Looking* 06 E60 M5 03 G35 Nismo Daily 01 996TT RWD/Stage 2+ turbo SOLD!! 02 500+ HP SC M3 SOLD |
#34
Hmmmmm, mine is popping out of FIRST......and at least once a day....and now I have noticed.......I am sitting at the light.....SOLIDLY in first....with my hand on it hold it "In" gear......and then when it happens....I blip the throttle and I just start to let out the clutch...and you feel the shifter jump ever so slightly and it grinds....cause I am holding it in....so it does it even if my hand is on it ............holding it in...
For you guys that had it jump out of 2nd.....would it still do it if you were "Holding" it in gear? Chris STILL hoping it's an adjustment........
2006 M5 Evo, Dinan, Singh Software, H&R 2001 F250 7.3 CrewCab Super Duty - 4x4 - Heavily Modded Tow Vehicle 1966 GT 350 Clone - 427 SBF - 570hp (Track Toy) ZRX 12R - Turbo'd - GS1100E All the right mods.... 2001 996 TT Arrest-Me-Red Stage 4 with FVD/GMG/SG Upgrades-Lots of Mods-Sold |
#35
Hey Chris, when I had my 2nd gear issue, it would pop out when going downhill at idle. If I held the shift knob, I could feel it move slightly forward like a 1/2 inch, but I could hold it and it would not pop-out.
As for your issue, I have no idea, and hope it is an adjustment, but the grind has me concerned. I would think it is the synchro at that point.
01 Arctic Silver Turbo. (GIAC II, Techart Type II nose,FVD Med w/dual tips,Evo V-Flow, Baileys DV's, Upgraded plugs, PSS9's , 19"Champion RG5's with 235/315 PS2's, B&M SSK, AS rear bumperettes, K40 front & rear, V1 hardwired, Smoked 3rd taillight & sidemarkers,Philip Silvervisions, Silver Crest,Misha GT2 wing = Daily Driver. |
#36
Popping out of 2nd -- 2003 X50 about 19k miles
Had the problem on my 2003 X50. My long sorry saga is here:
http://forums.rennlist.com/rennforum...d.php?t=249285 Porsche couldn't have handled this worse. Since I track the car at DE's, Porsche refused to cover under warranty. ... And told me to 'learn how to drive' ... Invoice for the repair is here: http://www.dinigroup.com/~mdini/tran...ice_2-2-06.pdf This is much more common than Porsche is admitting. |
#37
Interesting...reading the Rennlist thread....I noticed the statement made by Tom Kerr.......see below....
Is this true? This is good news to me..... I thought I had heard it was more like $6500 to rebuild......$3000 would be a lot easier on the budget.....who has had it down through an independent and what was the invoice? Chris 3. these trannies can be rebuilt way better (ie steel syncros, ect) for way cheaper.....WAY CHEAPER than a "new tranny" Brian Copans THE BEST IN THE COUNTRY (513-779-3302) quoted me about 3k from the time he receives it and sends it back (obviously the removal and install is on you) can also try Roger Brown at Powerhaus 303-442-4327. I have talked to both of these guys (alot) and both took alot of time with me and were very nice and I learned alot. Call them both.
#38
interesting ,.so heres my question say u get the car, its stock and all , and warranty is out on it for a while , and this 2nd gear pop out starts happening . will they cover it anyway since its a known problem ?
is there bulletin onthis that u could show them and argue ur point ? thats its very common ?? cuase thats BS that they know of this problem and there turning the other way .. im in the market for a 996 tt , and thsi scares the hell out of me , this happening , and them not wanting to cover it , and blowing an extra 12 k or whatver on this ... |
#39
Achiless heel?
'01 TT here - completely stock (including shifter). I first noticed the problem around 17K miles although it's entirely possible that it had existed earlier but I hadn't discovered it due to the specific driving circumstances that cause it to occur. Car has never been tracked or speed shifted, just the occassional spirited driving.
Thankfully, the service dept at my dealer was able to make a strong case for a new transmission thus convincing the extended warranty to go that route. If you follow the thread HERE, in the series of pics showing the engine and tranny, I've included a shot of the drain plug showing what I consider to be excessive metal filings! The transmission fluid also showed tiny particles that tested positively for Copper so there may well have been a synchro issue as well! There is no doubt that the 996TT powertrain is a technological marvel and certainly built for routine track duty but if it has an achiless heel, this has to be it!
'06 C6 Z06 LMB, Bone Stock '01 996 TT Seal Gray, Bone Stock '02 Z06 - GONE! |
#40
can anyone awnser my question on my above post ? im trying to find something on this but nothing.
#41
Quote:
If you're in the market, have the car checked out by an experienced and trustworthy shop/mechanic. Buying a certified car or one with a good extended warranty may be a good idea as well.
#42
Quote:
I know first hand all this happened to me and It was installed at the dealership. Its not only a pop out issue.... its coupled with 2nd gear not going in... meaning- stuff in the gate. I had that as well.
01 996TT built by Protomotive - 9.91 sec.145.64 mph 1/4 mile (4.78 sec. 60 to 130mph) 06 CLS AMG "You have an affair with an Italian(car).. but marry a German". |
#43
23 total voters so far: 16 had stock shifters, 7 had SSK's.
#44
unvmym3, I currently have the problem and I have another year of warranty plus 2 years of porsche pre-owned. The dealership is telling me that Porsche told them 80% of the "2nd gear" issues were due to abuse. So they are telling me that once they open the tranny it could be all my responibility. So if they are doing this to me with another 3 years of warranty, I am pretty sure they will charge for a car that is out of warranty (unless they feel in a giving mood or something)...
Current car: 996TT Blk/Blk Former cars: 2005 Aston Martin DB9 2002 Porsche Carrera 2 |
#45
what EXACTLY happens when 2nd gear pops out? I mean, does the shifter pop back to neutral, or does the shifter stay in place and just lose gear?
SOMETIMES if Im not careful, I only slide my "tequipment" SSK half way into second (user error) and dont put it down the whole way...it obviously came back out...but I have only done this once...
04 996 GT3-cobalt-Its a SCREAMER! 07 S8-Daytona Grey/Black-The HITMAN... BUH BYE>>> 06 CLS 500 Black on Black...smooth operator 01 996 TT-Arctic Silver-Stock Class J FOR SALE To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. (Gonna miss you!!!!!!) |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
