Rattling sound from the engine
Hi Guys..
Have an issue here regarding the rattling sound.. tsk tsk tsk.. Had this sound since day 1 when car was delivered. Was told that the engine is still warming up hence the rattling sound.. However it has been 2k miles since and this sound has never cease but louder especially after every drive..
What i've noticed -
1. Mild rattling sound when engine is on.
2. Sound gets louder after driving from point to point.
3. Sound could only be heard from outside, not while driving.
Is this a characteristic of a Porsche TT engine? Havent had a chance to compare with other 997 TTs yet.. Please advice.
Thanks.
Ron
What i've noticed -
Thanks.
Ron
I had a rattling engine as well. Your symptoms seem mostly the same as mine. I noticed the issue from the start but I got the car with 900 miles on it. As I would drive off I could hear the rattle and it could also be heard by bystanders.
The one time I had it checked (by slow test drive) the tech just said that it was normal, but I sensed that he was incorrect.
My engine failed and it was replaced. I don't know if the reason for the rattle was the same reason it failed, but as I suspected, the new engine was rattle free and ran much smoother. The car would now have more get up and go at lower rpms. The service people agreed that the new engine ran better.
The problem for you will be persuading the dealer that somethings wrong. You might have a seasoned tech stand outside as you start to pull away at low speed (as if you're driving in a parking lot). If you could demonstrate it you might convince the tech that the rattle sound can't be deemed normal.
If the rattle should not be there then it seems that others have this problem as well from what I'm reading here.
Best of luck to you!
It was something related to the number six cylinder going lean all of a sudden, melting a grove at the edge of the piston top, into the cylinder wall. I don't think it could be related but I am not that knowledgeable about the details of the engine. It may have been a coincidence.
Hi Guys..
What i've noticed -
Thanks.
Ron
What i've noticed -
Thanks.
Ron
This is a fairly old post, but getting the same rattle at low RPM. It shows up once the engine warms up. Hate it because it can be heard when pulling away outside the car and makes the engine sound bad, despite the cargraphic rumble... (which I admittedly step out to drown out the ticking noise...
https://www.6speedonline.com/forums/...eferrerid=7931
10-06-2015 03:43 PM
