Sponsored by: Bears Transport
eibach sport spring rates
Old 01-13-2009, 09:40 PM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
so i am still looking around for different options, and i know the bilstein damptronics r way to go, but i noticed eibach us has sport springs for 997 turbo, and i know somenbody mentioned here on the forum that they dont make it for turbo. has any body tried these springs out?
I called eibach and here are the specs for the springs, these should be close to gmg springs?
part # 7220.140
drop is . 8 inches
progressive f/r
F
19/34 nm
168/300 in/lbs
R
52 /90 nm
460/796 in/lbs
some food for thoughts.
Old 01-13-2009, 11:08 PM
Neeeenja's Avatar
Neeeenja is a jewel in the roughNeeeenja is a jewel in the roughNeeeenja is a jewel in the rough
Im selling some used techart springs...I believe they are made by eibach..correct me if Im wrong.
Old 01-14-2009, 08:52 AM
GEE-BEE's Avatar
GEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of light
Wink Spring's
I had to remove my GMG since I have a driveway angle problem at my other house...
My car is not the same with the stock spring's, Iam waiting to decide if Iam going to install them on my new C4S...
The ride is 50 % better and the handling is awesome with the GMG...
GMG
Best money I spent was on this Mod..
Gee-Bee
Old 01-14-2009, 09:00 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
That's the only problem with springs and coilovers, scraping the drive way IMO. Even though my car is no lower than my old 996 with RoW M030, it scrapes more. But, my stock springs scraped too, these cars have such a long front overhang they are a setup for scraping.
Old 01-14-2009, 09:17 AM
GEE-BEE's Avatar
Thumbs up ?
I have no problem with doing a angle when going in & out of the driveway now with stock height , If I were going to keep this TT I would probly go with the Cargraphic system ...
I think a new aftermarket lip that was 3/4 shorter height with a 3' tall rubber/silicone scraper seal on the bottom would be the best for these TT's
I would copy the mounting tab's on the stock OEM lip and then make a plug in type ( umbrella Type )seal that could be popped in place
Gee-Bee
We used to do this back in the late 70's on the Chastan kit's on various RS car's
Old 01-14-2009, 09:36 AM
damon@tirerack's Avatar
Moderator
I'm almost sure Eibach makes the Techart springs as well, BUT I think they are wound a bit more stiff than their Sport Springs are. H&R is also a bit stiffer than Eibach. My experience of late has been that the Eibach kits drop closer to what they say they will.
Both make a great kit, but neither will give out spring rates or they will have to shoot you.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old 01-14-2009, 10:41 AM
cgng30's Avatar
eibach did give me their spring rates above in my post , they wouldnt give me gmg or techart rates, it should be close? and lot cheaper
Old 01-14-2009, 11:51 AM
cannga's Avatar
Good job!!! I've made many phone calls and searched numerous posts, and this is the first time I see a manufacturer other than Bilstein releasing their specs for 997 after-market spring. Like someone said above, manufacturers/distributors almost act like they'll have to terminate you if they tell you the spring rates (and I understand).
It's unfortunate really -- we then have to make a decision between springs without the most basic of information. What's left is test drive, which is near impossible. So what's really left is someone else's opinion, or hearsay and rumor. (Interesting that Damon mentions H&R is stiffer than Eibach; I've heard of a well-spread rumor that H&R is softer than stock and have always been suspicious of that.)
A reason, minor perhaps, to go with a coilover set like KW or Bilstein -- no secret. Anyway, very interesting and pretty stiff "end" rates for the Eibach progressive spring.
part # 7220.140
drop is . 8 inches
progressive f/r
F
19/34 nm
168/300 in/lbs
R
52 /90 nm
460/796 in/lbs
Old 01-14-2009, 12:37 PM
KrafTechnik's Avatar
KrafTechnik will become famous soon enoughKrafTechnik will become famous soon enough
I'm pretty sure they didn't intend for the info to be posted on the forums
Regardless, I too am a big proponent of Bilsteins as I mentioned earlier this morning... Though on a non-PASM car I would probably go with KW's just because they are a more aggressive / flexible setup. I'm also surpised to see such a following for Eibach - we sell H&R 9 times out of 10
Old 01-14-2009, 01:20 PM
cgng30's Avatar
you sell 9 out of 10 h&r verses what esle, i see you only sell h&r springs
Old 01-14-2009, 02:47 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
part # 7220.140
drop is . 8 inches
progressive f/r
F
19/34 nm
168/300 in/lbs
R
52 /90 nm
460/796 in/lbs
I've got a set of Cargraphic springs made by h&r I would sell if you are interested.
Old 01-14-2009, 04:16 PM
bbywu's Avatar
Amen!
With all the buzz-words and hype aside...a huge part of the deicision has to do with spring rates, the dampers and objective numbers. How can anyone decide which is a "stiffer" spring if you have no idea what the spring rates are?
Even more laughable are comments like:
https://www.6speedonline.com/forums/2192559-post10.html
Best answer? (although it's probably overkill) Moton CS - and pick your own race springs and rates.
Old 01-14-2009, 05:12 PM
GotBoost?'s Avatar
Originally Posted by bbywu
Amen!
I agree. It's kind of stupid that they don't tell the consumer vital information to which to make a decision on. Spend a little more and go with some coilovers that give you a choice of srping rates. It's very well worth it.
Old 01-15-2009, 11:49 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Gentleman
Just wanted to clarify a few questions..
Both GMG and Techart use Eibach as our spring manufacturers. The spring material ( grade of wire) spring rates and spring design that we use are completely different than what Eibach uses for the general market.
The GMG WC springs are wound to our specification these are not rebranded springs like other manufactures use. Techarts design is exclusive to them just the same.
Our springs have been tested and tuned to the dampers in both sport and non sport modes to be comfortable, compliant and improve performance of the vehicle throughout the dampers range of stroke..
We have tested several other manufactures spring rates and have found that most of them actually use a softer spring rate than stock to achieve the lowered ride height. From over 8 different tuner and spring mnaufactures that we tested. The only springs that offered a stiffer spring rate throughout the complete range of compression were in fact the Techart springs..
Just an fyi...
Old 01-16-2009, 12:12 PM
cgng30's Avatar
Originally Posted by Fabryce@GMGRacing
Gentleman
Just an fyi...
fabryce
i understand that your springs rates are per your specs, but different spring material ? who makes that call gmg or eibach, and even so what is the difference in the material used for gmg springs and whats the advantage verses general market eibach springs, i always though it was only the spring rates that were different, and what exactly do you mean by stepless progressive springs, progressive is progressive?
also i know you refered one time that H&R were softer springs then stock, i am hearing opposite of that, i would say if the H&R springs are sofer then performance will suffer , which me and you agree, but contrary to that H&R/champion springs etc got good reviews on the performance side in magazines?
Quick Reply: eibach sport spring rates
