997 Turbo / GT22004–present Turbo discussion on the current model Porsche 911 Twin Turbo. Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
OK...so you use GT2 turbos...they must be expensive ))) and boost comes later then VTGs... now I see how its possible to make more power then other tuner with VTGs...
If i was to change VTGs i would go with Garett, cheaper and 771whp
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06 Lexus GS450h
07 merc SL350
08 Cayenne turbo
08 997 turbo convertible (Protomotive 700 under construction) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
No, they are larger than gt2 turbos(boasting more efficiency). Garretts are an options but VNT turbines offer better drivability and flatter/longer torque curves, also spooling faster. That is why porsche made the change.
Casey Parkin TPC Racing Marketing/Sales
410.799.7223 THE NEW To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Looking forward to your 1/4 and 60-130 times...
Sorry but as I know 997 GT2 turbos are also VTGs??They just come with larger wheels than the 997tt one but they are same unit..
The 997TT and 997GT2 both use VTG turbos, but they are not exactly the same. And the difference is more than the compressor wheels. Tuners can install bigger air wheel (46, 48 or 50 mm) to a 997TT VTG turbo, but the GT2 housing is larger over all. The inside dimensions are bigger on the intake side and exhaust housing are also larger. And while this may ultimately produce more power, my guess is they will likely have more lag.
07 997 Ruf Tuned Turbo
05 955 Cayenne Turbo - waiting for delivery
04 996 GT3 - sold, looking for replacement
02 996 Turbo - gone, but not forgotten
no problem.... 2 Turbos just showed up to get the treatment... so that will make 4 of these kits in the wild... One client requested that he wants more than 800HP...(has an LMP Panoz and a 962) so we are going to one up his car... should be exciting
__________________ View Our 105% Price Match Guarantee - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
View Our To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. at Texas Mile
Fastest K24/18G Tiptronic To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
