Go Back   6speedonline.com Forums > Porsche (Present) > 997 Turbo / GT2
997 Turbo / GT2 2004–present Turbo discussion on the current model Porsche 911 Twin Turbo.
Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 05-20-2009, 12:30 PM #46
milou is on a distinguished road
The point is you get 800hp with the GT2 turbos and some serious $$$, if i was going for over 700 i would bold a pair of Garetts and make 771whp
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06 Lexus GS450h
07 merc SL350
08 Cayenne turbo
08 997 turbo convertible (Protomotive 700 under construction)
Old 05-20-2009, 01:16 PM #47
Casey@TPCRacing's Avatar
Premium Sponsor
Casey@TPCRacing is a glorious beacon of lightCasey@TPCRacing is a glorious beacon of lightCasey@TPCRacing is a glorious beacon of lightCasey@TPCRacing is a glorious beacon of lightCasey@TPCRacing is a glorious beacon of lightCasey@TPCRacing is a glorious beacon of light
The purpose of this post is to show the difference in % that our 775Blitzkrieg makes over a stock 997TT.
This is a dyno graph that shows 3 different 997 Turbos. Our dynojet shows stock 997 Turbos to produce ~440 at the tire.
The Blue lines are a Stock car fresh off of the showroom floor. Notice how remarkably smooth the both the horsepower and torque curves are.
The Green lines are a car that came in with a generic mail order aftermarket flash.(THIS IS NOT OUR FLASH!)
The Red lines are from our 775Blitzkrieg Shop Car... As outlined in the first post of this thread. Notice the smooth and plateau like torque curve.
Keep in mind that the turbos we use are modified 997TT Turbos, not GT2 turbos that have been modified. Our turbos are 33% more efficient than GT2 Turbos.
Also I was doing some research and I saw that another well respected tuner has a dynosheet of a baseline 997TT making 438.179 WHP on an AWD Mustang Dyno, nearly identical to our 2wd Dynojet.
So, to recap: TPC's 775Blitzkrieg makes 52% more power than stock.
Casey Parkin
TPC Racing
Marketing/Sales
410.799.7223
THE NEW
Old 05-20-2009, 03:39 PM #48
997John is a jewel in the rough997John is a jewel in the rough997John is a jewel in the rough997John is a jewel in the rough
Quote:
You said on your post # 11 those are GT2 turbos !!
2007 997tt-Proto 60-130 in 6.75, 200-300 in 13.5 sec.
2009 Lexus 570
2010 1500 Sierra 440cid with two small turbos (In progress)
Old 05-20-2009, 08:54 PM #49
Premium Sponsor
Sorry, These are modded VNTs... pretty much laid out the specs in the turbo section up above:
"Turbo Chargers:
At the heart of our 775B 997TT system are our modified VNT turbochargers. The 775B turbo chargers feature a 2.0mm larger compressor inducer than the stock GT2 and a 1.5mm larger exducer. TPC highly modified turbine section increases swallowing capacity to help create a plateau like torque band, ensuring tremendous power throughout the rev-range. This amounts to a 33% more efficient turbo than a factory GT2 unit!"
Most tuners dont disclose these kinds of numbers but we laid it out as we know it works.
Sorry for any confusion. The turbos are significantly different from the normal 997TT variety and even are different from the GT2 as stated above.
Casey Parkin
TPC Racing
Marketing/Sales
410.799.7223
THE NEW
Old 05-21-2009, 12:22 AM #50
TT Surgeon's Avatar
TT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud ofTT Surgeon has much to be proud of
Looks geat, but are you saying that a bone stock 997tt lays down 440hp to the wheels?
That's about 50hp more than I have seen a stocker do on a 4wd dynodynamics dyno..
Doesn't seem like enough drive train loss, ie 20%, is factored in, am I reading your post right?
Chris
'07 997TT Midnight/Sea...
Farnbacher-Loles prepped
'09 Cayenne S Blk/Blk; wifey
Old 05-21-2009, 04:24 AM #51
Premium Sponsor
yep, we see 440 and if you look at other companies baselines they report the same.
Casey Parkin
TPC Racing
Marketing/Sales
410.799.7223
THE NEW
Old 05-21-2009, 10:01 AM #52
eclou's Avatar
eclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond reputeeclou has a reputation beyond repute
bit of a problem with your dyno's posted above regarding correction factors:
run #1 (blue) temp = 66.7 F, baro pressure = 29.77 in-Hg, humidity = 36% (vapor pressure = 0.238 in-Hg) your dyno correction factor should be 0.97 not 1.00
run #2 (green) temp = 90.02 F, baro pressure = 30.06 i-nHg, humidity = 7% (vapor pressure = 0.101 in-Hg) your dyno correction factor should be 0.98 not 1.01
run # 3 (red) temp = 84.04 F, baro pressure = 29.54 in-Hg, humidity = 26% (vapor pressure = 0.307 in-Hg) your dyno correction factor should be 1.00 not 1.03
08 Cayenne TT
07 997 tt
97 993 tt GIAC/AWE K24
86 944 turbo track car K27/6
Old 05-21-2009, 11:09 AM #53
carlover08 is on a distinguished road
wow this is awsome ...........................................
Old 05-21-2009, 12:32 PM #54
224hp more than stock, more than enough for me.
2009 Lexus 570
Old 05-21-2009, 04:23 PM #55
What about that proto John?
06 Lexus GS450h
07 merc SL350
08 Cayenne turbo
Old 05-21-2009, 10:10 PM #56
TT Surgeon's Avatar
Hmmm
All I'm saying is that when I had mine worked on/tuned at farnbacher-loles (also a good shop), a stock 08 997tt laid down 387 at the wheels with a DD dyno, I can't see how 440 is possible. That's like almost nil for drivetrain loss.
Chris
Old 05-22-2009, 03:24 AM #57
Quote:
So far so good. As you know about the human needs always looking for more and more, and thats what we are working for with Todd.
2009 Lexus 570
Old 05-23-2009, 06:47 AM #58
GT RUS's Avatar
GT RUS will become famous soon enough
What is the price of this kit ???
SWITZER 997 TT TipS SPI 750
1/4 in 10.29 at 132.5
"IF NOT FAST then YOU LAST"
Old 05-23-2009, 10:32 AM #59
TTdude's Avatar
TTdude is a splendid one to beholdTTdude is a splendid one to beholdTTdude is a splendid one to beholdTTdude is a splendid one to beholdTTdude is a splendid one to beholdTTdude is a splendid one to beholdTTdude is a splendid one to behold
It's good to be accurate but the difference in correction factors seem minimal and probably outside experimental error anyhow. How many runs on the dyno does it take to get the best plot, 10? If would be interesting to plot averages with error bars and see what the curve looks like.
"Officer, I wasn't speed'n but I sure was pass'n some that were"
Old 05-29-2009, 09:01 AM #60
Premium Sponsor
Tons of emails and PMs regarding this. Currently 2 cars at the shop being upgraded. Pretty exciting! lots of projects at the shop currently!
Casey Parkin
TPC Racing
Marketing/Sales
410.799.7223
THE NEW
Reply
Tags
060, 775, 775blitzkrieg, 911, 997, 997tt, dyno, fastest, gt2, mustang, order, porsche, stock, tpc, turbo, vnt
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
