997 Turbo / GT22004–present Turbo discussion on the current model Porsche 911 Twin Turbo. Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Ok, grab a beer (or two) for this mod, wont take that long. Special thanks to bbywu for the heads up on what to look for during this install.
I went with the Hoen endurance (yellow). The pics dont do them justice, I rarely use the fogs but when I do I want ones that actually work in fog or rain.
If you want to match your HID lights go with the xenonmatch.
Tools needed: none, but thin flathead comes in handy to remove connector if its a bit dirty.
1. Lift the car, I used a jack and stands. Whatever you do make sure its SAFE AND SECURE. You want to get enough clearance in the front to get under the car easy enough with some movement for your arms.
2. Look for the tubular device, it stores the H3 fog light bulb and mechanism.
3. Unplug the connector leading to this device.
4. Twist (counter clockwise) a few degrees the bulb housing (tubular), then pull down to gain access to the bulb mechanism.
5. disconnect wiring to remove mechanism (turn left a few degrees and pull down to remove the mechanism, much like the tubular housing)
6. remove factory bulb and replace with aftermarket bulb
7. reverse process to re-install
Reinstalling the mechanism is tricky, there are 3 tabs, make sure they align correctly to make the job much easier. The smaller your hands are the easier this mod will be as the working space is quite tight.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
I took some but at night the added time to take the pic with the shutter made them all blurry! I need a tripod bad. Will get some good ones posted asap.
Have not gotten around to take some new ones, but here is one of the least worst shaky ones!
They are much more yellow in person than this pic shows, I definately recommend them over the white ones as its impossible to get the low beam, fogs and LEDs matching.
Thanks for the detailed write-up and supporting pics, G-Money! The fog lights will complement my newly installed Hoen turn signal xenons. Thanks for making it an easy decision!
__________________ Shawminator '09 Turbo Cab Cargrahic Exhaust HRE P40's
