997 Turbo / GT22004–present Turbo discussion on the current model Porsche 911 Twin Turbo. Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I just thought I would share my experience with Dr Colorchip. This is a product that touches up pait without the "blobs" of pens. I met one of the owners a few years back and saw him fix a nice chip on a guards red turbo.
Well my Basalt Black car had some stone chips on the trunk lid that mad it look "linty", so I figured I would give it a try.
I ordered the biggest amount, not knowing it would be too much. I followed the directions, as well as remembering what I had seen previously.
Impressions:
It certainly "blacked out" the chips so they were only noticeable if you were looking, but even after 3 or 4 tries, it doesn't even out the surface. That is my biggest complaint. Otherwise it works as billed. Supposedly you should wait a week before waxing over it.
Essentially it is a good product for masking the areas, but doesn't fill the areas...certainly less noticeable that the paint stick "blob".
I found it worked better on metal than plastic.
Sorry no pics.
My guess is it is better on darker colors.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
handdoc To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I've used numerous touch up products, and thus far, nothing is perfect. But on my Mini, I was able to remove one chip to nearly 90% perfection using Dr C. On my Audi, they sent the factory coded paint, it did not match well, and I indicated what I needed tint-wise, and they sent new that matched perfectly.
Remember, unless you are painting a panel in a downdraft system using professional equipment and expertise, NOTHING is going to mask these chips 100%. But this stuff was one product I liked enough to buy more than once.
Because it lays down thinner than the blobby paint pens and other products, try to do it a few times in one weekend, and see if you get enough build. Also leave the paint a bit longer before the 'wipe' and you might get better results.
Eric Chief Plug Guy
Check us out! We do custom paintwork on all Porsche parts!
2009 Turbo Cab
Gone but not forgotten
2004 C4S Cabriolet
Guards Red/Beige Full Leather/Black Top
Lots o'goodies To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I too have mixed emotions about both DR. C and Lanka, both are supposed to do the same thing. Ultimately, neither really do on darker color cars. On my lighter color car, I had much different results, not perfect, but better.
I use DR. Color Chip on all of my cars. Its a great system. As far as touch up paint goes, there's nothing better. You cannot expect perfection. Chances are you're the only one who can notice the touchup.
Do you apply using supplied brush? Try applying a small blob near chip and smear with a credit card using light pressure. Do it several times and it chip should fill with paint. It will not be shiny as the clear coat but hardly noticeable. Applying clear coat over repaired chip might improve it. Is there a color code for the clear coat that Porsche uses?
2009 Carrera C2 Stock To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
yes i used the supplied brush and followed the instructions (as well as what i had seen one of the designers do)...they warn you about excess paint...did you try this credut card thing that you mention
no clue on clear coat...after a coat of klasse sealer it looked awesome
Always been a bit wary of the aftermarket paint kits. Tried one of the paint 'pens' for my M5. Worked okay, but not great.
Decided to get the OEM touch up paint from Porsche. At least this way, I know the color will be an exact match. Will be filling in some chips this weekend. Anyone ever use the stuff? Tips?
Best way to permenantly remove chips is to paint, sand, and polish.
1. Clean surface with wiping alcohol.
2. Using the tip of a plastic toothpick, get a small drop of paint (clearcoat+basecoat mix) into the chip using capillary action.
3. Repeat 2 every 4 hours until new paint is nearly flush with surface. Let paint sit overnight.
4. Wet sand chip until you cannot feel it with your fingers.
5. Use rubbing compound to eliminate sanding paper scratches.
6. Use polish to remove finer scratches.
'08 Jerez Black M3 Coupé DCT
Retired: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. / To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. / '07 Salsa Red VW Sagitar / '04 Milano Red Acura TSX
