Go Back   6speedonline.com Forums > Porsche (Present) > 997 Turbo / GT2
997 Turbo / GT2 2004–present Turbo discussion on the current model Porsche 911 Twin Turbo.
Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-28-2009, 07:10 PM #1
vividracing's Avatar
Platinum Sponsor
2007 Porsche 911
vividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond repute
Send a message via AIM to vividracing Send a message via MSN to vividracing Send a message via Yahoo to vividracing Send a message via Skype™ to vividracing
After 10 Months, We Introduce The VR825 997TT Power Kit with GT3076 Turbos
I am really proud of this guys. The parts came out amazing, the results were strong, and I think you will find this just another reason we have been proving ourselves on this forum. Since this is the general forum, no prices... But I am offer 1 kit with FREE Installation and Transportation to Vivid Racing. Enjoy!
Streetability, high performance, racing inspired, and proven testing are all words to describe the VR825 power package for the 2007 to 2009 Porsche 997 Turbo. With a true bolt-on Garrett turbo kit for the 996 Turbo in our history, we wanted to take the same development, but enhance it 100% for the 997 Turbo. Realization of what the stock 997 Turbo motor was capable of, set us on the path to create this power kit. Beginning R&D in December 2008, we thrived to develop a bolt-on turbo kit that was capable of 1000 horsepower with engine modifications. For those 997 Turbo owners that do not want to touch the internals of the engine and keep the driveability as well as functionality of their car on a day to day basis is where we end at the VR825 Power Kit. This kit was designed around the daily driver and built to give your 997 Turbo the driveability of a stock car while around town or headed to dinner. However once you get into boost, the car is an insane piece of equipment designed to test your foots threshold.
Performance:
As tested on our own Porsche 997TT demo car, the VR825 package makes some impressive numbers under real world conditions. We use a Mustang All Wheel Drive Dyno to do our tuning and view delta changes while kept in the most consistent conditions. The Mustang AWD loaded dynamometers are designed to duplicate real world operating conditions. The patented control system uses eddy current power absorbers to load a vehicle exactly the way it would be loaded on the street -- including wind resistance, which is a significant factor in high-speed testing. The Mustang dyno does read lower then other dynamometers out there. We also only test our cars the way they come from the factory, in all wheel drive. Our car in its stock form baselined at 387 all wheel horsepower. With the completed VR Power Kit, the car produced an incredible uncorrected 756 all wheel horsepower. With the correction factor of the Mustang Dyno, this was a plotted dyno amount of 687 all wheel horsepower. Mustang Dyno's have approximately a 20-25% drivetrain loss which gives our car 825 horsepower to the crank. These tests were done using MS109 race gas and running at 1.5bar on a 4th gear pull. In addition to these strong dyno numbers, we have also brought the car out to test in normal driving scenarios. Using the industry standard GPS based Performance Box with a non-professional driver, our car ran a 60-130mph time in 6.33 seconds. Our 0-60mph was logged at 3.5 seconds. Finally we achieved a standing mile run at 195.7mph with a 10mph NE head wind. Based upon the non controllable factors, the platform of this kit is designed to beat any supercar from 0-200mph!
Product Details:
The core of the VR825 kit is based around Garrett GT3076 .63a/r turbochargers. Together, these ball bearing turbos spool up similar to the stock VTG turbos, however deliver nearly 400 horsepower more of mid to top end power to be used in any driving situation. In conjunction with the Garrett turbos, we utilize Tial 44mm .8bar external wastegates which bypass the stock exhaust system to create brain punishing torque at full boost. The use of these turbos and wastegates requires special headers as the fitment is different then stock. Our headers are hand built in-house using 16 gauge, 304 stainless steel that is TIG welded. Our thick water jetted flanges and custom made merge collector provides you the best performance. The headers bolt to the heads the same, except use a 4 bolt flange to mount the Garrett turbos and require an extension just off the collector for the external wastegate. The turbos cannot make the power on their own and require additional products that we have manufacturer specifically for the VR825 kit. In addition to the headers to mount the turbos, you must also change the oil and water lines. Porsche uses proprietary fittings for their oil and water lines to the VTG turbos. We supply new AN fittings, steel braided oil lines, coated water lines, and banjo bolt fittings to mount to the Garrett turbos. So customers can retain their stock mounted aftermarket exhausts with the Garrett turbos, we include steel black oxide coated exhaust adapters which mount to the turbos to bolt the exhaust too. This enables you to retain your favorite aftermarket exhaust sound and style with out having to get a custom one made.
Turbocharged vehicles need to receive air, and cool air for that matter. Because the stock air box or aftermarket intakes still do not provide the flow and cooler air temps we require, we have relocated the intakes to the fender ducts over the intercoolers. The custom made Agency Power aluminum intake pipes feature appropriate diameter and bends to give you the clearance and retain OEM trim pieces. Once installed, the filter sits on top of the intercoolers inside the modified plastic housing to receive direct and cool air away from the engine bay. The intake pipes include a 1-inch return port for the blow off valve to recirculate. Each intake pipe is connected to the turbo with a 90 degree reinforced silicone coupler. The OEM MAF tube which is removed from the stock intake fits between a high flow K&N cone filter and provided silicone coupler to complete the system. Continuing with our cooling system, we modify the Agency Power high flow bar and plate intercoolers and include the lower 5ply silicone boost hoses that connect to the turbochargers. These intercoolers are 40% more efficient then the stock units. The modified intercoolers feature 76mm aluminum outlets going into the Y-Pipe. This allows us to maintain a full 76mm diameter all the way to the throttle body. The aluminum Y-Pipe features smoother transitions and an internal air guide to efficiently bring air into the engine. Since the stock VTG internal boost recirculation valves are deleted, we include dual Agency Power adjustable blow off valves off of the Y-Pipe. These valves are designed to vent 50/50. This means that 50% of the air is recirculating back into the intake pipe 50% is going to atmosphere. This keeps the MAF sensor happy eliminating any stalling or idle issues 100% vent BOV's cause while helping the turbos stay spooled between shifts by venting out 50% of the air. The Y-Pipe features a CNC machined mount for the stock MAP sensor and a side mount for the Greddy Profec B boost controller required to use with the Garrett turbos. The kit also includes a special laser jet aluminum plate to separate your moving pulleys and belts from anything that may fall in the way. Not only is this for safety, it also cleans up the engine bay. Next to achieve more air into the intake manifolds, we use the Agency Power race plenum kit. The plenum kit includes the 78mm Cayenne Turbo throttle body mounted to our matching larger aluminum T plenum. All of these pipes are then finished in your choice of powdercoat for an OEM or show look.
Because this kit is using Tial 44mm external wastegates, it is not possible to control the boost with the factory solenoid. We include the Greddy Profec B boost controller which enables you to have different boost settings for pump and race fuel. The Greddy has a high and low boost setting as well as a digital boost read out, memory for peak boost, and even a warning feature in case of over boosting. What brings all of this performance together is the custom ECU tuning by Softronic. Softronic allows you to flash your ECU through the OBDII port of the vehicle. Their ECU flash for the VR825 kit is designed to eliminate any warning lights from the removal of the VTG turbos. The flash will also raise your rev limiter by 500rpm's and will retain the sport mode feature for better throttle response. For those running catless, Softronic raises the O2 sensor limiters to avoid any check engine lights. Softronic reads out a full 1mb of the file to tune each individual timing and lambda tables. This ensures you get the best tune the first time with built in parameters to adjust to race gas and fuel mixtures. With the appropriate MS109 octane fuel, the car can safely run 1.5bar of boost and on pump fuel, 1.3 bar.
Outside of the above listed products, it is required to have an upgraded clutch and performance exhaust system to run this turbo kit. For the clutch system, we recommend the Clutch Masters Stage 3 full disk or Twin Plate with integrated flywheel. Exhaust systems are relatively equal and anything with a high flow muffler and 200cell or less catalytic converters will be sufficient. For those in hotter climates, we recommend equipping the car with an AEM water/meth injection kit while running pump fuel. Individual parts are available through Agency Power dealers while the VR825 kit is exclusively available through Vivid Racing. Full installation instructions are provided and fitment is recommended only for professional mechanics. Vivid Racing does offer transportation to our facility for installation of this kit. VR825 kits installed at Vivid Racing receive an additional 2 year/15,000 mile warranty on parts and labor. For any questions, please contact porsche@vividracing.com or call us at 1-866-44-VIVID.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Largest 6Speed ONLINE
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Dan |
1-866-44-VIVID | 1-480-966-3040 x222
***WE SHIP WorldWide***
Old 10-28-2009, 09:24 PM #2
ranger66's Avatar
ranger66 is on a distinguished road
Send a message via AIM to ranger66 Send a message via Yahoo to ranger66
Wow good work and impressive numbers.
RLTW
09 Honda Accord CPE
08 RR Sport
08 Corvette CPE
07 Escalade EXT
06 BMW 650I
Old 10-29-2009, 09:14 AM #3
Platinum Sponsor
2007 Porsche 911
Thanks Ranger!
Dan |
Old 10-29-2009, 02:24 PM #4
AWD's Avatar
AWD AWD is offline
AWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud ofAWD has much to be proud of
Thumbs up
The kit looks great and VERY complete!
I wish I had a Turbo, as the free install and transport is a superb offer!
Upcoming projects....Under Construction!
Old 10-29-2009, 02:27 PM #5
Platinum Sponsor
2007 Porsche 911
1 kit is being installed on a customers car in Washington next week. Should hear back on that soon. We will have our online instructions put up Tuesday as we are refitting all the pieces back to my car on Monday.
And yes... that is a good deal
Dan |
Old 10-29-2009, 03:01 PM #6
997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of
TPC's 775Blitzkreig ran the 1/4mi in 10.65 trapping @ 135.2mph! (detuned/ran on "pump" gas) WHAT UP?
Old 10-29-2009, 03:05 PM #7
Platinum Sponsor
2007 Porsche 911
You might want to look at how they dyno cars and their dyno type as those 2 cannot be compared. Also take a look at the trap speeds, they are within 1 mph of each other. You have 2 totally different cars, different environments/tracks, and different drivers. As far as the octane type, there is no way to verify what anyone is really running. Props to TPC for their achievments.
Dan |
Old 10-29-2009, 03:40 PM #8
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
Hey Dan, cool product, from the video, seems like you had a hard time getting off the line... Probably take some vital times off...
08 Porsche 997TT. Black/Black
08 Maserati Gran Turismo. Black/Black
07 Cadillac Escalade. Black/Black
Old 10-29-2009, 03:42 PM #9
Platinum Sponsor
2007 Porsche 911
Yeah you can see the difference in the driver taking off in the TX Mile video. We will get some new runs next week. It was 50F this morning!
Dan |
Old 10-29-2009, 03:47 PM #10
SRatha's Avatar
you are also right about the 2 different dynos as well... its just not a fair comparison, i'd like to see real numbers if you were to trade dynos... what would the numbers be...
Old 10-29-2009, 03:51 PM #11
Platinum Sponsor
2007 Porsche 911
The real benchmark is the 60-130mph, 1/4 mile trap speed, and the Mile. Giving props to EVO, their EVT850 did the Texas Mile in a 197ish, so I feel our car is on point.
Dan |
Old 10-29-2009, 04:07 PM #12
Quote:
just playing devil's advocate; Vivid is @ 825bhp, TPC <775bhp (detuned for the run), should it have been that close? (1/4mi & trap). TPC announced new intercooler (hybrid?); should do sub 10 mid 9s! TIA for reply
Old 10-29-2009, 04:10 PM #13
Platinum Sponsor
2007 Porsche 911
So a new intercooler will take me to the 9's? Sign me up
Dan |
Old 10-29-2009, 04:58 PM #14
Casey@TPCRacing's Avatar
Premium Sponsor
Casey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to beholdCasey@TPCRacing is a splendid one to behold
Thanks Dan, I had an S4 the same color as your turbo.
Casey Parkin
TPC Racing
Marketing/Sales
410.799.7223
THE NEW
Old 10-30-2009, 09:10 AM #15
Platinum Sponsor
2007 Porsche 911
Nagaro blue? We had a 2001 back in the day. Those things were awesome.
Dan |
Reply
Tags
911, 997, gt3076, manual, o2, porsche, sensor, turbo, turbos
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
