Go Back   6speedonline.com Forums > Porsche (Present) > 997 Turbo / GT2
997 Turbo / GT2 2004–present Turbo discussion on the current model Porsche 911 Twin Turbo.
Sponsored By SharkWerks, Inc
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 11-03-2009, 12:04 AM #31
bbywu's Avatar
2007 Porsche 911
bbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond reputebbywu has a reputation beyond repute
Quote:
Originally Posted by GT3 Chuck View Post
here is what the stock GT3 droplink looks like...
These were from a very much missed Moton equipped 996 GT3...also looked a little weak.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
07 997 Ruf Tuned Turbo
05 955 Cayenne Turbo - waiting for delivery
04 996 GT3 - sold, looking for replacement
02 996 Turbo - gone, but not forgotten
Old 11-03-2009, 12:07 AM #32
GT3 Chuck's Avatar
Super Moderator
GT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond reputeGT3 Chuck has a reputation beyond repute
if you like the settings the way they are then adjust the link to the same length as the stock link and install with same preload...it is possible that you could soften the front end slightly by removing the preload on the front bar...
Old 11-03-2009, 01:24 AM #33
NeilM's Avatar
2008 Porsche 911
NeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant futureNeilM has a brilliant future
Quote:
Originally Posted by bbywu View Post
I'm assuming installation goes as removing the old twiggy set, mounting top bolt to suspension and lower bolt to sway under load, and then adjusting the length and locking it with the counter bolt.
Anyone have any other hints?
Best to do it while the car is on an alignment rack to have preload. Did mine twice myself. Make sure that you don't over-extend the bottom part of the link. This will push the sway bar down a bit then will hit the control arm when turning into driveways and hitting bumps(you'll hear it). I have the RSS dlinks and had to tighten them twice already. This may be due to me not tightening them quite enough. This past weekend, I used red loctite on both top and bottom adjustment nuts before tightening them once again. This may solve the loosening problem. Use a 12mm wrench to hold the body while you use a 17mm wrench to tighten to top and bottom nuts once you have it at the desired length. Should take you no more than 30mins per corner.
ID:	108978   Click image for larger version
ID:	108980   Click image for larger version
ID:	108981   Click image for larger version
- Neil
~ '08 Silver 997TT Cab (Techart wheels, Bilstein B16 Coilovers, RSS swaybars, RSS front drop links, Short Shifter, Fabspeed intake/headers, Tubi Street exhaust, EVOMSit tune)
~ '03 Range Rover HSE
~ '10 MBenz GLK350 4Matic
~ '07 BMW M6 Cab
(sold)
Old 11-03-2009, 06:18 AM #34
obsessed's Avatar
obsessed is just really niceobsessed is just really niceobsessed is just really niceobsessed is just really nice
[quote=NeilM;2605344] This past weekend, I used red loctite on both top and bottom adjustment nuts before tightening them once again. This may solve the loosening problem.
Loctite ia great idea. Blue may be a better choice - relatively easy to adjust later with hand tools, red may need hammering and heat to remove if more than a dot is used.
2006 997S
2006 AM Vantage
Old 11-03-2009, 07:58 AM #35
TT Gasman's Avatar
TT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to beholdTT Gasman is a splendid one to behold
Nice pic. I have to wonder if the drop link is really under a lot of stress, or is it more a question of proper geometry? All the OEM drop links are similar on the TT, GT3,GT2...
Doug
Houston, Texas
'07 997 TT-> RUF 550 R Turbo
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
'08 Cayenne GTS
"Screw you, we're from Texas"...Ray Wylie Hubbard
Old 11-03-2009, 09:43 AM #36
obsessed's Avatar
When set on stiff you can often see the inside wheel lifted off the track by sway bar when cornering hard - fair amount of stress to lift the wheel fighting the weight of the corner of the car and the spring. I am sure geometry is a factor but heft is probably more important. Lighter links may survive the street but not the track.
2006 997S
2006 AM Vantage
Old 11-03-2009, 03:15 PM #37
TT Gasman's Avatar
What's the downside to using a heavier duty drop link with metal heim joints on the street? Has anyone considered ride height as an issue with the drop links?. Does anyone know the relative lengths of the drop links, stock/Bilstein/GT2?
Doug
Houston, Texas
'08 Cayenne GTS
Old 11-03-2009, 09:42 PM #38
bbywu's Avatar
2007 Porsche 911
I'm going to open a can of worms here. I am hoping that sponsors do not respond, rather end users...
RSS, ERP, GMG, Tarett, TRG...many manufacturers. Many similarities. Some with great history in racing, some are newcomers. Some rumors out there that one company produces products for others, re-branded and anodized, then resold.
Preferences?
Old 11-03-2009, 10:48 PM #39
GT3 Chuck's Avatar
Super Moderator
more like a box of worms...I would not hesitate to recommend any of them...my personal experience...I have all Tarett parts (droplinks f+r, rear upper monoballs, rear toe links and locking plates...all first rate stuff...when I did my mods I did not know GMG or RSS but their parts look equally as good..I could have just as easily gone with TRG or ERP but I had talked to Ira and he was very helpful and gave me a good deal...I would say look at them all and go with the one that feels right to you
Old 11-04-2009, 05:51 AM #40
obsessed's Avatar
What's the downside to using a heavier duty drop link with metal heim joints on the street? Has anyone considered ride height as an issue with the drop links?. Does anyone know the relative lengths of the drop links, stock/Bilstein/GT2? [quote]
Based on my experience with these mods, no downside on street from droplinks with solid bushings. Impact on street ride comes mostly from solid bushings in steering and solid shock mounts, wouldn't do those if not a track rat willing to compromise street comfort. However, you can also do toe bars with solid bushings in rear, to keep toe from shifting on hard cornering, with no noticable deterioration in street ride. The adjustable links should cover you with any reasonable street or track height, extended links are said to provide better geometry - relationship of motion of the sway bar to movement of the car - I went with extended links and am very happy with the set up. I can't say there is a significant difference in ride, but to me it was worth the few extra bucks for "the best set up" to avoid buyers remorse and the risk of wanting to upgrade again later.
2006 997S
2006 AM Vantage
Old 11-04-2009, 02:46 PM #41
TT Gasman's Avatar
I guess my main issue with the metal heim joints is durability on the street, not ride quality. On a track car that is cleaned up regularly and stored in a garage it's no big deal. On the street, the car is exposed to moisture and dirt etc, all these could prematurely wear out the metal to metal heim and loosen it.
Doug
Houston, Texas
'08 Cayenne GTS
Old 11-04-2009, 04:34 PM #42
obsessed's Avatar
Quote:
Fair point, but have seen several reports of rubber/plastic joints breaking haven't seen metal ones reported failing - but that doesn't mean it doesn't happen. I did see a thread a while back where someone located rubber seals to install on the metal joints but I did not pursue that, maybe I will try to check into that - wouldn't hurt. My car is used on street and track but mods are biased towards track use.
2006 997S
2006 AM Vantage
Old 11-04-2009, 05:53 PM #43
GT3 Chuck's Avatar
Super Moderator
I don't think it is a concern for any of the quality parts mentioned above...just beware of cheaper ones that have aluminum bushings that have been known to elongate at the bolt holes...
Old 11-04-2009, 09:11 PM #44
TT Gasman's Avatar
Lowered ride height may still be a factor, didn't the same thing occur on 993s dropped to RS ride heights? And the cure, prior to the availability of RS drop links, was to cut and weld the stock drop links. Are the 997TTs with failed drop links lowered to GT2 ride heights or below? That's what I was getting at with the relative lengths of the drop links, is the Bilstein between the stock and the GT2?
Doug
Houston, Texas
'08 Cayenne GTS
Old 11-04-2009, 09:27 PM #45
bbywu's Avatar
2007 Porsche 911
First picture is of Sparkhill's damaged Bilstein drop link, installed incorrectly. Note the direction of the drop link bolt on the damper. It is inserted on the shock from behind. The lower end is inboard of the sway.
Second picture is of Sparkhill's new RSS link. Note the direction of the drop link bolt on the shock...it is again from the rear. And now, the lower end is outboard of the sway.
Does this look correct? I thought the bolt was suppposed to be from the front on the top, and inboard on the sway?
The reason I ask, is because the third photo shows a TechArt/Bilstein setup with the drop link on the inboard of the sway, but the drop link bolts on the damper from behind...kind of like the way the Bilstein drop link was installed incorrectly.
ID:	109132   Click image for larger version
ID:	109133   Click image for larger version
Reply
Tags
550r, ruf
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
