Help pls (urgent): What is this fluid leak from beneath turbo housing?
Yes, yes, and no comment
It looks like coolant....The turbo itself has a coolant line going to it...You could have a bad o-ring or maybe it came loose...Worse case would be what happened to Ed...But I think you would have a much bigger puddle...
Can,
You are bad luck man, I just noticed that my turbo is leaking again as well, my garage floor looks exactly like yours. I had it fixed a couple of months ago and have only driven the car twice since then. Dealer said it was a loose clamp, but now I am starting to wonder. As soon as the weather clears its back to the dealer for me. I sure would like to know what you find out when you get yours back
If it's oily and red, it could also be coolant. Pray it's not b/c it may mean a failed coolant pipe = trip to dealer, engine out, lots of labor to replace one stupid part. Not that I would know anything about that......
Read here:
https://www.6speedonline.com/forums/...ark-werks.html
Read here:
Car is safely at dealer and I won't hear until Monday.
Ed, you're scaring me. Question: was the leak in your car a slow gradual one like mine, or was it a sudden catastrophic dump? I am thinking (hoping) if it's a slow leak, then hopefully it's just a loose hose somewhere else that perhaps won't require an engine drop
If there was a slow leak, I never noticed it. It was sudden and catastrophic. Fortunately, the car was parked at the time.
Just noticed a small leak under mine. Its on the drivers side and appears to be coming from the engine block to metal coolant elbow. There are 2 of them one on each side of the crankcase and extend forward from the rear from a rubber gasket. It has what looks like a bleed nipple in the center of the elbow. Fluid appears clear and has no smell and doesn't feel oily.It is wet up around the flange at the engine block end. Any similar issues out there from this area?
Chris,
it looks like its coming from the tube beside the elbow. I put the camera under the car and snapped a few more shots. Not sure if this makes it clearer but its hard to get a perspective shot.
stevenrmusic
Bentley
17
11-12-2015 05:53 PM
ECS Tuning - VW
08-20-2015 03:07 PM
ECS Tuning - BMW
08-19-2015 09:29 AM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
