Official 997 turbo picture thread.
#436
Fabspeed exhaust headers w/merge collectors and Fabspeed 2.75” mufflers (Protomotive exhaust in route) - Tial Alpha 3076 turbochargers with water line kit (internal wastegate)
- Bilstein PSS10 Coil-over lowering kit
- Eibach front and rear sway bars
- Protomotive MAF-less ECU tune optimized for 104 octane unleaded fuel
- Custom in-tank, triple pump, E85 compatible fuel system with dual feeds (one to each injector rail) and Bosch 1680cc pump/E85 compatible injectors
- Custom built fender intakes for turbochargers with K&N Filters
- EVOMS Upgraded Aluminum Intercoolers w/custom duct work
- Protomotive re-ground and pinned 997TT camshafts on intake and re-ground exhaust cams
- Paramount Performance Full Tiptronic Transmission build w/2500rpm stall converter
- NAG1 Stage II Performance valve body upgrade
- Protomotive TCU tune to remove torque limits, change RPM limits for shifts and improved shift speed
- HKS EVC 6 Color Electronic Boost Controller
- EVOMS Billet Diverter Valves mounted on intercoolers
- Porsche Techquipment Factory 4-point roll cage
- 911 Design built 3.8L engine with welded coolant fittings, Sharkwerks SS coolant fittings, Protomotive 7/16” head studs, custom Pauter rods, Cometic MLS head gaskets
- Vorsteiner front bumper, carbon fiber front splitter, rear wing and turbo intake sleeves
- MACarbon carbon fiber side mirrors
- Agency Power rear carbon fiber diffuser
- Rennlin pedals
- GT2RS red door pulls and red seatbelts
- 19” HRE P40 (MHTs in route)
- Pioneer AVIC-8000NEX, Focal speakers, JL Audio 8” sub
- Escort Passport MAX radar detector and AL Priority Laser Jammer
- DCT steering wheel in route
#438
Very nice!! Paint looks beautiful as well. Have any interior pics?
Any chance you can remove the stickers on the underside of the wing?
What kind of power are you making with your set-up?
#450
could you put up a few pics of your interior...is it a leather to sample? flamenco...sounds cool...
