End pipes warning...
If you have NAPA auto parts store near you, they have thicker one.
I read this thread last week and then today had a flashback to it. I pulled out of the parking lot and heard a little burble and then all of a sudden the car got a whole lot louder. Sure glad I pulled over within a few blocks because my AWE exhaust "arm" coming from the muffler can (not just the tip) had come loose!!!!! Thankfully it was just dangling in the bumper hole so I put it inside the car and drove home with the surprisingly deafening din coming from the exhaust. I usually check the bolts at least a couple of times a year. This is the first time I've taken the car out of hibernation while it's still pretty cold outside (about -5C or around 28F, but nice and sunny). Perhaps the heat cycles were enough to cause it to wiggle loose? Damn, I know I'd rather have an exhaust that was "one-piece" rather than modular.
I have the maxspeed dual (true dual exhaust) tips on my 997.1 turbo. I cleaned the inside edges of the mounting ends of tips and male exhaust pipe tip with denatured alcohol, dried with shop towels then used a thin bead of high temp Permatex Gasket Sealer which I smyred out around the inside of the quad tip. Aligned them equidistant from the plastic shroud in exhaust well to avoid melting it from excessive heat, then torqued the bolts to spec.
The hoop strength created from the gasket sealer should keep them from falling off. Mine have been on for over year now, with hard driving and no issues, let it sit overnight before spirited driving.
That's my "full ***" way of doing it...
The gasket seal was a good idea, if they come loose again I'll try that.
I had this happen a few years back with fabspeed tips. They were clamped down all the way but one still flew off. The tip was beat up bad. Fabspeed took care of it with a new pair and they are still in place..If I was you i would see if they replace the tip.
Well I will mail Vividracing and see what they have to say, I used the thin ones since it was the only ones that fitted.
joseph_number1
07-19-2018 05:45 PM
nlakind
11-06-2015 10:15 AM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
