335/30R18 fit on a 997.1 Turbo?
On my 997.1 turbo track setup I run Toyo R888 335/30R18's in the rear on 18x12 +48 offset rims. They sit perfectly flush on the car with oem camber settings, because of the additional tyre width I do not run more camber on the rear than oem for my track/autocross setup. "Get Your Wheels" on this forum was extremely helpful and recommended the +48 offset after discussions with me, I could not be happier with the fitment look.
My car is not lowered, due to our public road conditions and speed control bumps in the suburbs.
Thank-you sir!
I am using 265/35R18's on 18x9 +50 offset rims on the front. They slightly protrude the wheel arches with oem camber settings, but with more camber upfront they also sit flush.
This setup has less difference in diameter between front and rear than the oem setup, up till now I have had no diff problems.
Fwiw, on track I run r888 with 255/35/18 in the front and 335/30/18 rear. The rims are 9.0 @ +50mm & 12.0 @ +48mm. I'm lowered with -1 camber in front and -2 camber rear. The front is flush and the rear is 5mm inset (in case I run a wider 335).
Hoping you guys can answer this. I have 20" HREs and want to do the Michelin Cup tires.... I run Michilin PSS's right now at 325/25/20. Cups don't come in that size. I would have to go 335/25/20. Will that fit?
they handle like poop (compared to non runflats). WAY too stiff. it'll be easy to bend a rim.
edit, looks like you might have to do a 315/25 michelin cup instead (N rated too !!!), as the 335s only come in runflat. 3/10ths of an inch narrower (but because youre running a 12, it will look just the same visually)
COBB Tuning
11-09-2015 08:02 PM
oddjob142
08-19-2015 12:27 PM
