P3000 Fault, Help!
P3000 Fault, Help!
Just had a Europipe stage 1.5 exhaust fitted with 4 new lambda sensors, after 50 miles i got the check engine light on speedo. Ran a durametric scan and shows P3000 fault. The fault comes back on straight away when i clear it.
Is the bank 1 sensor 1 (pre cat?) faulty as its showing as no signal/communication?
I have checked all wiring and its all plugged in and there's no damage to wiring. Please help.
Yes, its the sensor 1, bank 1. (sensor with blue wire cover)
Passenger side in RHD cars.
Check the pins inside the lambda sensor connector, sometimes they are bent while installing.
(on the left side of the factory airbox)
ESMOTOR
Home of the Worlds quickest Porsches
1/4 mile: 7,95 @ 190 mph
100-200km/h: 2.16 sec
200-300km/h: 3.43 sec
60-130mph: 2.52 sec
100-150mph: 2.19 sec
Email: emre@esmotor.com.tr
Web: http://www.esmotor.com.tr
Instagram: http://www.instagram.com/esmotor
ESMOTOR
60-130mph: 2.52 sec
Good luck.
DC
Thanks guys for the replies i will check this in the morning. fingers crossed
I've just changed both pre cat Lambda's as they were both faulty or wrong ones?? Now the p3000 fault is gone.
I drove the car for a couple of hours and re scanned the dme and now i have B0821 fault.
Is it post cat lambda related or spark plug/ coil pack issue?
I cleared the fault and its not come back up straight away so maybe just a minor???
DC
