997.2 Turbo S does 6.49 sec 60-130 in 1,800 DA
Sorry to hear you are having troubles. That's weird you would be at the fuel max by adding the y-pipe. I'm running that exact setup with no problems and a couple 997.2 guys have all that plus 68s. I would have just taken it off after having the runs get crappier.
Just curious, does it happen at WOT or part throttle and do you have any codes?
The dimpled y pipe did add substantial midrange to my car too. I love it
Longboarder was running a file that was known to fuel cut for this event. He wanted to see if supplementing with additional octane would stop fuel cut from occurring at high speeds (over 130 mph). The additional octane was working well enough, until he added the larger Y-pipe.
To clarify, he hasn't had one single issue with the release version of the 9 second file, even with the Y-pipe. In fact, he was able to hit his fastest trap speed with that file and the Y-pipe upgrade, while in pump mode.
I don't have any info on IDC%. Our motors are completely different...mine is the new 3.8 litre direction injection motor.
Thanks dzenno!
Likewise nice meeting/chatting with you and it was great to see John again.
Vid uploading now
Fuse 116 unleaded (108 motor octane) from vendor Emmanuele Design:
https://www.6speedonline.com/forums/...race-fuel.html
Thanks!
You should know that there was an FVD tuned Turbo S at the event and it did great!
Vid uploading now
Thanks!
Looking at my 60-130's on Sunday on the 91 octane pump gas file the car ran very consistent. My 60-130s were: 7.585, 7.095, 6.637, 7.240, 6.922, 6.829, 6.819, and 6.857. I think this was chronological so as you can see the ECU had to re-adapt and generally got faster as the day progressed even though it got warmer.
Saturday was more volatile and the 60-130's ranged from 6.49 to 7.64. When fuel cuts were hit my car would buck and blow out black smoke.
Got some more data guys if interested. Loaded up my vBox .dbn file to www.vboxtools.com for some reason my file is too large on Saturday so it won't load but here's my results Sunday when I was on the pump 91 tune:
0-60 mph 2.870 seconds (lol could not hook up at all on that dusty airstrip)
0-100 mph 5.997 seconds
0-150 mph 13.311 seconds
100-200 kph 5.694 seconds
60-130 mph 6.637 seconds
1/8 mile low ET 6.970 seconds @ 107.354 mph
1/8 mile high trap 7.783 seconds @ 108.299 mph
1/4 mile low ET 10.629 seconds @ 134.643 mph (terminal trap 135.7627)
1/4 mile high trap 11.401 seconds @ 135.787 mph (terminal trap 136.8299)
Pretty sure that's the top 1/4 mile trap stock turbo ever for a 997.2. And that's not even on race mode lol. I need to contact my buddy Robert runs that site so I can get my Saturday .dbn file to load up because I'm sure I've got a higher 1/4 mile trap there.
Cheers
Cheers
Robert (Pencilgeek) was able to split my Saturday dbn file into two smaller files. While I didn't best my Sunday 1/4 mile trap (likely due to fuel cuts post 130mph, I was able to get the graph of the 6.49 second 60-130 run which I attached to my first post.
Cheers.
Cheers.
Funny how it took me spinning like crazy on the launch to get that mph lol. That airstrip is very dusty as I tried to capture on my airstrip vid, you actually have to launch over a painted surface which just kills any attempt at good traction. I did some 10.6X ETs on the vBox this weekend all with poor launches so I'm eager to get to the drags with a properly-prepped launch pad to see if it will turn a 9.X on street tires.
Hey Austin, yes that file worked fine for months until the Y pipe was installed haha. The Y pipe flowed great and we gained power but hit the fuel limit. But these events are for exactly that. We found the fuel limit and then backed down power on Sunday. Now I need to see if my Aquamist system will give me the fuel to try that file again.
I been there with the fuel cut on top end, the Aquamist system will not settle the problem but for sure it will put your IAT very low to protect your engine, will not gain you whp but is something that is a 100% safe
I figured as much but since my kit is just laying around not being used I might as well give it a shot. I know it's not going to give me a lot of fuel, but maybe it will give me just enough fuel to go back to the "Saturday" 9-second file that had the fuel cuts but also gave me the 6.49 60-130 time. I think that file probably has another 10 to 15-hp which would be nice. A 75/25 meth/water mixture or even 100% meth may do the trick but I typically don't like to run high meth concentrations because I've had meth lines crack on me many times. With this car, I'm not messing around and will use stainless steel lines with Howerton heat wrap and aircraft grade fittings.
Got it thanks.
Sure better on the car that on your garage... I have mine and with the hot weather here and all the abuse that I make to the car the Meth is a bless for my engine hehehe... BTW just between you and me, ALL meth systems works better with 50/50 mix... don't believe otherwise
