My 997.2 Turbo Video @ the Track... Enjoy
Nice run, I like it! Can you tell a difference by doing a burnout? I normally avoid the water box and consistently get 1.5-1.6 60-foot times. I always wondered if having a drag radial and doing a burnout would improve that time.
I am down on boost, most likely from a boost leak which I think I have had from the second I did the IC's. I checked everything.
I dont have time to work on it and I don't like being rushed, so I am going to ask my Friend Enzo to look into it.
This was on 18 PSI according to Cobb and 93 octane. Stock turbos. Right side turbo is screaming though. I can hear it in the cabin.
She better go mid 10's or I am selling and getting a GTR.
Dammit, Enzo Performance put it on the dyno, and it makes a lot of power. So they dont think it has a boost leak. Jeez. Now what? Bigger turbos? Decisions decisions. I am not happy unless this car goes mid 10's all day @ 135.
As you know dyno's all read differently so I wouldn't put much into the number. Best bet is to log data and send to someone like Mitch@Cobb or dzenno@pft to see if everything is ok. Tune only you should see 10.6-10.8 at 130 if you are in the northeast with low DA but you need to use launch control - is your car a 2010 with no LC? I did a 10.6 @ 130 at a bad SoCal track at 600ft DA with tune+plenum and stock Michelin PSS tires full weight no burnout as a comparison.
The dyno I went to reads low compared to others. I went to a ****ty track day with no prep. So I was hoping a 130 mph+. I am running an off the shelf tune with cobb. I think Mitch needs to tune it since I hace IC's. When I said it made power, I meant it matched other porsches with exact mods. So now what? I am waiting to see if the one turbo is an issue as it had oil in the intake pipe.
No worries Gary let's turn her up and see how she does
PORSCHE EXPERT GROUP - TIM BAILEY | JARED BRONSON | GRANT EPHROSS | ANDREW SCHWARZKOPF | HJ LEE
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | CONTACT US
I meant the car had no boost leaks and is acting correctly on the dyno. I also meant to say that the car makes the same power or similar power to other porsches with similar mods. I think turning her up will help. She was on 18 PSI. Enzo is helping me out, because I am working on a massive project at work, and don't even have time to type correctly so it seems. Sorry for the bad typing before. Mitch, can you email me a more aggressive tune? When will you be in NY or CT or PA?
But you should still be in the 10's with a 128 trap. I would try some different launch techniques first.
I don't think doing a burnout is a good idea unless you are on drag radials or slicks. It does nothing for traction on street tires and heats up the car.
It also doesn't sound like you are using launch control and your car is bogging the start.
To increase your trap speeds, you could try some old drag racer techniques...bring some ice and ice down the Y pipe in between runs. Also bring a water sprayer and wet down the intercoolers. I don't have the luxury of east coast density altitudes but it seems to help me particularly when it's 80+ degrees and after a run my engine bay is an oven and the intercoolers are heat soaked.
Shoot me an email Gary we can figure something out.
Mitch
