Anyone running Bilstein B8 shocks?
Hi all,
Is anyone running Bilstein B8 Dampatronic shorter shocks with lowering springs? These are the fixed height struts, not the B16 Dampatronic coilovers. For a 2010 Gen 2 Turbo.
If so feedback would be great, which springs you have, how it rides on bad roads, if you track your car etc.
I'm considering B8's, H&R or Eibach lowering springs & H&R antiroll bars front and rear for my Gen 2 Turbo. Wondering which spring rates match the dampers best, H&R looks best drop wise, but still want some compliance on the roads. If not too bad will go for these.
Not a fan of the stock suspension or arch gap.
Thanks for any help.
M
M
Great choice. Basically porsche motorsports designed these to be the x73 for the 997 platform, when vw took over in full this was scuttled along with a lot of projects.
It's a great option, better than damntronics IMHO. Ride great on the street and handle well on the track.
Gmg springs are great with these.
I'm surprised Bilstein do not recommend springs to go with these. You should speak to Chris at Centre Gravity
Would love a ride if you do go for this set up. Have been looking for a sport set up which controls the mass of a turbo without knocking all my fillings out for ages
Thanks for the replies all. I'm going to speak to Bilstein tomorrow, see if I can get an insight into which spring rates are going to best suit the dampers specs.
From my research on here Eibach seem to be the more compliant of the two on roads using OEM dampers, with some reporting H&R are a little bouncy on poorer surfaces. But the Bilsteins are slightly shorter with different rebound rates so the H&R's could be ideal, maybe I have to be guinea pig lol
@TT Surgeon - re x73, do you know which spring manufacturer they were going to use for this kit?
Obviously we also have Techart (made by Eibach, apparently with slightly differerent specs) or GMG (made by Eibach also?) but both are expensive for me to get here in the UK so ideally, want to stick with the aforementioned brands unless I'm compromising my setup.
Porsche had their own spring with the x73, it was fairly stiff in the 996 variant.
I think any aftermarket sprung will work well with the b8.
How would you compare the ride to the B16's - if I recall you were running those and had issues with them?
I've just gone through another very expensive exercise and now believe that the shock is the issue. I'm looking for alternatives, and this is a very viable one.
https://www.6speedonline.com/forums/...placing-4.html
Yeah - wouldn't wish it on anyone
Yes you do need to get rid of the "Crap-stein" Damptronics - and do it now IMHO, not just talk about it. I haven't said anything because first I thought you were right it was the shock, but after 3 times, no I don't think so.
The B8 here would be an excellent choice. Regarding the springs for B8: because it is made for aftermarket (AM) lowering springs, the choice is limited to these 3-4 AM springs, and no one knows the spring rates. This is the difference between B8 and B16: B16 use standard linear springs and you could change to whatever rate you like, B8 use progressive lowering springs with unknown rates. There has been argument that linear spring (stiff from very beginning) is more fun than progressive (first soft, then stiff, to make it more street friendly), but some race cars use progressive, so who knows. The other difference is B8 has fixed ride height that is determine by the spring (a rather large 20mm drop that might be too much for some people), whereas B16 has adjustable ride height. (There is a non PASM B16 called B16 PSS10 that is a good alternative for people who don't want PASM.) Regardless, B8 is an excellent idea for your car, IMHO. At least it will eliminate a lot of questions - really trying to help here.
I used the gmg toes, theirs are based on the gt3cup.
I think those are the same length that I use, so the Tarett hopefully should fit. I need to verify this somehow...
Are you using an experienced and Porsche specific tech for your car? If not, I would suggest that you find a replacement before going further. Really, if he is the same person who has replaced the Bilstein 3 times in your car without suggesting a different approach, I would not trust him anymore.
