Sponsored by: Bears Transport
New Project 4.0L 1200HP
Old 05-16-2015, 05:07 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
As some of you may know am running ESmotor built engine and turbos kit .. Car is fine and running very strong , but because I was running pauter Rods , we were afraid to run higher boost level (2.0bar Max) to not damage the Rods .. Because from what I heared 1000 TQ is max !!
Engine will go to ESmotor to get refreshed and rebuilt with :
- 4.0l Mahle pistons
-carillo Rods
- bigger heads same as GT3 spec
- Esmotor head studs
Will update you with pics and videos
Regards
Old 05-17-2015, 12:26 AM
Tareq's Avatar
Tareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant future
Thumbs up Mashallah
Salam Yousaf, That is great news, inshallah it will be a monster
Keep us updated with pictures and videos!
Goodluck!
Old 05-17-2015, 01:55 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Good Luck !
Consider upgrading the hta35 with gtx35 , remember that salih 4.1 hta35 could not go faster than 3.8s 60-130 maxed out
Old 05-17-2015, 07:19 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
who has bent Pauter rods from horsepower and not detonation id be curious to see.
Old 05-17-2015, 08:12 AM
cjv's Avatar
cjv
cjv is offline
Moderator
-carillo Rods
Regards
Unless things have changed, the Pauter rods have more mass. They are heavier and given your rpm range should be just fine. For the most part both Pauter and Carillo are off the shelf rods. If you want a lighter, built to spec rod give Arrow Precision a call.
They will be more expensive, but given what you are spending .... it is all relative.
Old 05-17-2015, 09:01 AM
ysfg35's Avatar
Goodluck!
Inshalah bro , I will keep you update it
Old 05-17-2015, 09:03 AM
ysfg35's Avatar
Originally Posted by porschecayenne92
Good Luck !
Well let's see the difference from 2.0bar to 2.3bar plus the GT3 spec heads
Old 05-17-2015, 09:06 AM
ysfg35's Avatar
Hello chad , well I emailed puater asking them the max TQ the rods can handle and they told me Max is 1000tq !!!!
I will go with custom ESmotor Carillo rods that suppose to hold 1900hp
Old 05-17-2015, 09:07 AM
ysfg35's Avatar
Originally Posted by mcoupe mus
Sounds good Yousaf!
Will be a monster once done
Thanks buddy
Hope so
Old 05-17-2015, 09:10 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Sorry if I'm missing the obvious, but is this a 997.1?
I see .2 taillights in your avatar but I know some people convert them.
Good luck with the build. Esmotor has been putting out monsters in all of the platforms.
Old 05-17-2015, 12:00 PM
kadiri 997's Avatar
kadiri 997 is a jewel in the roughkadiri 997 is a jewel in the roughkadiri 997 is a jewel in the roughkadiri 997 is a jewel in the rough
Maybe they are referring to foot pounds which is 1355NM.you will hit the limit of your tip transmission before you reach the limit of the rods.
Old 05-17-2015, 01:37 PM
pwdrhound's Avatar
The above information is incorrect. I have Pauter rods in my engine and they came in lighter than comparable Carillos. The Pauters with the beefier ARP625 bolts are 536g versus 540g for the Carillos with the CARR bolts. The Pauters are 32g lighter than OEM rods. As far as strength goes, can anyone point out an engine that bent Pauters rods? I am not aware of one and was told by Pauter they have been used in 1200hp applications without issues. If anything, I would think due to the nature of the design, the Pauters have less windage than the Carillos. I don't think you can go wrong with either Pauter or Carillo.
Old 05-17-2015, 03:33 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Best of luck to you and your new build! Hope to see some awesome times!
Old 05-17-2015, 04:25 PM
ysfg35's Avatar
Nobody said pauter rods are bad , am running them since 2 years with zero issue , 2.0bar all the time with hta3586 turbos .. Never failure .. But I do not want to take a risk damaging the engine if the rods got bent !
ysfg35's Avatar
Thanks Antony.
Quick Reply: New Project 4.0L 1200HP
