Kline Inconel 997.2 Turbo S
I have not put it on the track yet , been too busy but will let you know when I do. Not for nothing long boarder can shed plenty of YouTube light on that . Correct me if I'm wrong but LB you ave been adding mods along the way so you can attest to how the car will perform modded w/ out upgraded ic's against higher hp cars
Also for that matter Sam and Mitch can share on that too they both are top notch, I couldn't be happier with both of them
Yes I started with "Stage 1" GIAC tune and IPD plenum only. Then went "Stage 2" which added the Champion intercoolers and BBI exhaust with 200 cel cats relocated away from turbos. Then later added the IPD Y pipe.
While I don't have dyno's other than stock (501/536 AWHP/AWTQ on cobb's socal mustang dyno), I would say stage 1 got me to 530 AWHP on pump 91 and 550 on Race gas, and then Stage 2 got me to 570 AWHP on pump and 580-600 on race gas. Now I'm at stage 2+ with meth and a more aggressive tune. And the best thing is that I do not suffer any heat soak at all. Car runs 100% in the hottest environments imaginable, which I have done 100+ degree F track days even prior to the meth. The intercoolers are really incredible.
Mini George
07-29-2019 12:20 PM
Mini George
01-18-2016 09:16 PM
