My turbo is now in for repairs...need advise
I posted a few weeks ago about some misfires
https://www.6speedonline.com/forums/...ble-997-a.html
It's in the shop with a guy I trust. He's been working on Porsches his whole life, tough I will admit, most of his experience is with 996 turbos and older. He does have experience with 997, just not as much. Anyway, he got into the car today and figured out the last guys to work on it 2.5 years ago only hand tightened the plugs, used the incorrect plugs (or at least not the ones recommended by evoms), stripped a few exhausted bolts and did not have a boost hose on well (stripped that too). Otherwise, no big deal and all fixable...
Here's the issue now. He says there is at least 0.020" axial play in the turbos and he is recommending I send them off for rebuild before having him put them back. Car has 38k, seems a bit early, but ok. Where should I send them and what will it cost? Is this one of those deals where it would be better to upgrade the VTGs (champion?) and intecoolers and go big hp? Thanks again to the forum!
that could be really expensive if the turbo decides to take a dump into the engine
That amount of play is perfectly fine. A journal turbo should always have some play when there is no oil pressure, as it is this space that is consumed by pressurized oil. Your turbos are likely perfectly fine, so there is no need to spend money unless you want to upgrade.
it guy has a 1000 hp turbo he built himself. full shop with5 axis cnc machinery 3d printers etc. he can build just about anything you need and some things you didn't know you needed!
he is the guy who i pm'd you about
If you're looking for turbos, I'm selling mine - perfect working order:
https://www.6speedonline.com/forums/...ml#post4344796
So, it does appear I had a small boost leak on the right allowing the right turbo to over-spin. It will need to be addressed... I'll let you guys know which direction this heads
hoeferland
11-10-2015 05:42 PM
pumptech
11-08-2015 01:22 PM
