Vivid DRL's cloudy (pic)
I've been on the fence about this mod. I like the way that LED DRLs look. I like the idea of a modified light that replaces the OE turn signal, because it doesn't really change the appearance of the car. I also thought about changing my fog lights for DRLs like the 997.2, but I actually use my fog lights. We get quite a bit of fog up in the mountains. I guess the biggest thing holding me back is that I'm concerned about the reliability and lifespan of the aftermarket LEDs. Any thoughts?
or..
you can check into FVD or some of the other manufacturers.. I dont have any experience with them yet.
I would presume they come from the same manufacturer. Unless this is a high volume product where multiple companies are willing to spend 10's of thousands of $$$ for each manufacturer to make a new mockup, mold, and minimum bulk order.
Just buff and coat the lens...
They do not dim like Mercedes .
Not sure if this is just how my set is wired, or if its the only option.
A lot of time the haziness could come from inside if they were not sealed correctly during the drying process. The material is a plastic called PC (polycarbonate) - it can show haziness with a certain amount of heat so no matter how much you buff them on the inside, the haziness will still be there - just be careful how much pressure you apply - it will be very unlikely you will damage them, but if you work on them for a while and nothing happens...stop...you will get more and more frustrated.
I got this mod done in 2013 on my 997.2 and frankly I don't like the way it looks now. Cheap design / execution and there is water condensation on the inside. And from driving in front of the car at night makes the car seem very "narrow" (is the only way I can describe it). I'm going back to stock and turning on the stock day time running light which is the single fog light which spaced at the end of the bumper more appropriately and makes the car seem much wider. My 2cents.
+1000 was just about to write the same.
DC
Anyone know if there is an option to re-wire these DRLs so the stock settings are present? The stock setting on the 997.2 is for the fog lights to always be on in the day when the main lights are not on. I believe once the main lights are turned on then the fogs are off (from what I remember???). And then the DRLs only act as a blinker.
Thanks.
Thanks.
flatsixing
12-02-2023 12:47 AM
gtron
03-03-2020 02:00 PM
dgreen78
04-30-2016 07:18 AM
